Z6 motor have a knock sensor ?
Doing an ODB0 to ODB1 conversion and it says to connect a wiring to the Knock sensor, but I thought only the Y8 had a knock sensor. I have a pin right abouve my oil filter, but I thought it was oil presure. Thanx in advance.
Z6 dont have knock sensors your right that single prong is the oil pressure switch. Your using a P28 ECU correct, that doesn't recognize a knock sensor anyways thats just incase you go with a OBD1 DOHC V-tec ECU
EK_vzla
Feb 3, 2004 06:32 AM
