ZC axles help NEEDED!!!
i got 89 integra exles. i did a seach and people are saying everythign from 89,90 to 85 accord se-I axles. i have 89 right now but the driver is a bitch to go in and the passenger is in but it looks a little tight. does anyone know what exles are for sure. any help thanks.
what transmission are you using? if it is ZC, you need 90-93 integra axles - the 85 accord se-i axle for the passenger side is about 1/2 inch longer than the integra and works better on cars that are not lowered, since the integra axles will sometimes pop the outer cv joint apart on hard right turns at low speed - 89 integra does not work
ok i got 89 integra axles alredy...the passenger is in just a lil stretch..the driver goes in with a 1/2 inch sticking out. i even hit it with a hammer and it wont go in anymore????????????????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote"> - 89 integra does not work</TD></TR></TABLE>
that is incorrect, i have a ZC in a 91 hatch WITH a ZC tranny and i'm using 2 passenger side axles. Tehy been in for well over a year and never had a problem.
OK, i'll tell you, if you have the zc tranny and the zc intermediate shaft (that's good cause you need that intermediate shaft) You have to get the 90-93 integra axles after that, it will fit like a charm.
so what if you dont have the ZC intermediate shaft? can you use the 90-93 integ axles w/ intermediate shaft as well? i have a d16a6 with a ZC tranny, and my ZC axles are already going bad, and i need replacements.
crxguy406
Jun 29, 2013 09:50 PM
dohcnotec
Jun 26, 2004 11:47 PM
