ZC Engine Specifications and what years/models it came in
Old Apr 30, 2003 | 11:12 PM
Ahknodd's Avatar
Default ZC Engine Specifications and what years/models it came in
I am wondering what are the specifications of the ZC DOHC engine that came out in 88-91. I also want to know what cars it came in. Like did it come in the civic only or was it available on the Integra? Also was it sold here in the United States? And one rumor that I am confused about is that the ZC is actually a ZC D16; is this true or not? Thanks- Davey
Old Apr 30, 2003 | 11:26 PM
Malgerus's Avatar
Default Re: ZC Engine Specifications and what years/models it came in (Ahknodd)
Well I can help a little bit. I'm not a D series guy, but I do know that the first gen ZC came in the 88-91 Civic/CRX Si's, JDM. (I think Europe got the D16A8/D16A9, which is basically the same thing). The ZC IS a D16. It's very similar to the D16A1 that came in the US Integras prior to 1990.
Old May 1, 2003 | 06:08 AM
jlicrx's Avatar
Default Re: ZC Engine Specifications and what years/models it came in (Mr. S)
basically correct - the 1st gen ZC is referred to as the brown valve cover ZC and bolts into 1st gen crx & 3d gen civic - the 2nd gen ZC is the black valve cover and bolts into the 2nd gen crx and 4th gen civic - they are D series and share a lot of parts with the D16A1 and D16A3, but they are not the same.
Old May 1, 2003 | 07:47 AM
turboZChatch's Avatar
Dohc zc black valve cover
bore and stroke 75x90 mm
Compression ratio 9.5 with cat 9.1 with out cat
displacement 1.590cm3 (cc) 97 cubic inhes
hp 125-130 depending on who you ask (6800 rpm)
4 valaves per cylinder total of 16
1.6 liter
b16er
Oct 20, 2006 07:05 PM
SpankyofNOLA
Dec 29, 2004 09:05 AM
South Bay Surfer
Apr 6, 2004 09:19 PM
1badrex
18
Oct 10, 2003 07:23 AM
Kasper.
Aug 3, 2002 07:02 AM
