anyone know the complete specs to the k20?
Old Apr 30, 2003 | 05:32 PM
i HAVEtheADVANtage
Guest
Posts: n/a
Default anyone know the complete specs to the k20?
I was thinking about putting a little more money into my car, instead of dropping a b18c5 into the car, and be a little more original and get the DC5 motor. But i dont know a lot about them other than the fact that they pull out some serious power.
Old Apr 30, 2003 | 06:01 PM
i HAVEtheADVANtage
Guest
Posts: n/a
Default Re: anyone know the complete specs to the k20? (i've_got_the_ADVANtage)
and does the k20a come with LSD?
Old Apr 30, 2003 | 07:02 PM
Neukin's Avatar
this is all i found...Engine Specs
HP 220 @ 8000RPM
Torque 152 lb/ft @ 7000 RPM
Redline 8400 RPM
Bore 86mm
Stroke 86mm
Comp Ratio 11.5:1
Displacement 1998cc
Specific output 110HP/L
Trans Specs
1st 3.27:1
2nd 2.13:1
3rd 1.57:1
4th 1.21:1
5th .97:1
6th .78:1
Final Drive 4.76:1
Old Apr 30, 2003 | 07:05 PM
i HAVEtheADVANtage
Guest
Posts: n/a
Default Re: anyone know the complete specs to the k20? (toyosupr)
much appreciated.
but im looking into more technicals. IE lift of VTEC cams, more on VTC in the gears, and etc.....i just want to know if the k20a is worth my time.
Old Apr 30, 2003 | 07:57 PM
redronin22's Avatar
it would kill a b18 no questions asked. It makes something the b18 didnmt have down low. torque!
plus its 20 lighter then the b series =-)...
Old Apr 30, 2003 | 09:12 PM
DC5RK20A's Avatar
What are you looking to install it into? Obviously you know that they rotate clockwise versus the B series counter clockwise rotation. I think it will take some cash to drop it into an older style chassis. If you have the cash, I say go for it, the K series will surpass the B series soon enough. The B series has had a great run, and will still continue to see support from the market, but the K is the new blood of Honda, so much untapped potential.
Chris
Old Apr 30, 2003 | 10:02 PM
i HAVEtheADVANtage
Guest
Posts: n/a
Default Re: (DC5RK20A)
2000 EK. not much of an older chassis. but still kick *** motor. thanks for your opinion. i love the k20a
Old Apr 30, 2003 | 10:04 PM
i HAVEtheADVANtage
Guest
Posts: n/a
Default Re: (i've_got_the_ADVANtage)
and if you have a k20a DC5 ( judging by your SN ) ddoes your car have LSD?
Old Apr 30, 2003 | 11:08 PM
jaynsee79's Avatar
the k20a does have an lsd which is not a bad one for a stock. dont get me wrong, it does the job but like anything else out there, there is always better. i wish my dc5 had an lsd.
Old May 2, 2003 | 08:29 PM
DC5-R's Avatar
Default Re: (dc5ricerocket)
the DC5R LSD i believe is a 1 way LSD...
splagga
Apr 28, 2006 07:49 AM
TerribleOne
May 15, 2003 06:00 PM
RR98ITR
Mar 31, 2003 11:49 AM
InfamousRS
Dec 5, 2001 08:59 PM
