i have gsr head, can i change just one cam, or do i need both???
hey guys...i want to upgrade to ITR/CTR cams but i think i heard that you only need to get one of them (dont remember which one)...is one of them the same as the GSR, or do you need to do both???..
i know i should just do both anyways while im in there, but when your strapped for cash you do what you can...
thanks for the help
thanks for the help
i know alot of peeps that only put in the ITR intake cam, and gives a noticeable gain, but putting in both of course is better. there is an overlap issue if u just put in 1 cam
Get both! Unless you're getting just the Intake cam for REALLY cheap.
Also remember to upgrade valvesprings.
How strapped are you? Just save and wait until you have money to "do things right the first time."
EDITed.
Modified by 96dc2 at 7:06 PM 4/30/2003
EDITed.
Why would you upgrade cams to a cam with a higher redline only to take your motor to the old cams redline? (shakes his head) Do it right the first time.
not sure if u read his post...but he's only doing itr cams...sheesh. they dont make power past 8k anyways. what...you would raise the limiter just to squeeze maybe.5 hp?!!
aftermarket cams are a different story
i want to change the cams (one or both, not sure yet) to the ITR's...
but if i dont raise the rev limiter are you saying i wont see a difference???
someone help!!!!
someone help!!!!
happyabortion
10
Dec 11, 2008 07:17 PM
Vtecme92
Oct 15, 2005 07:53 PM
Sleepin Crx
Jan 13, 2004 10:39 PM
tmekjian
Apr 30, 2003 06:03 PM
