Sunroof will pop up, but not slide back.
My sunroof dosn't work all the way. The sunroof will pop up, but it will not slide back. Have any of you all had the same problem? I've already taken the switch apart and sanded down all of the contacts? Any ideas? TIA
my friend had the same problem with his sunroof in his crx, drench all the rails and all moving parts in the actual sunroof
with liquid wrench, worked for him
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J Money »</TD></TR><TR><TD CLASS="quote">I'm going to try that right now. Does anybody else have any ideas?</TD></TR></TABLE>
couldnt help ya but here's a bump.
I had the same problem with mine and the railes were really dirty and the sunroof turned out to be off track a little. just make sure it's all the way on the tracks and clean up the rails, worked for me so far.
Does it sound like it wants to move or does it sound like the motor took a crap? The motor on cars only has like a 7 or so life span(depends on the use). You will be able to tell if it did.
I've removed the switch twice now and sanded down the contacts until there was no plastic on them. I am still having the same problem though. I'm going to try a different switch this weekend. I hope that works. Any other ideas?
Damn, you guys are making me feel a little bit better about my sunroof problems. It's too bad that we all don't live closer together. We should put a sunroof repair write-up on here. Any other ideas?
schueytenten
Jul 10, 2007 03:36 AM
jdmturbo1127
10
May 25, 2007 06:48 PM
IneedBoostInTheCoupe
Dec 16, 2006 03:48 PM
projektCRX
15
May 2, 2004 07:07 PM
