PLEASE HELP Need Torque specs: Cam Holders?
I dont have a haynes manual, and the only place close to me doesn't have one
I need the torque specs on the two bolts that are on the the things that hold the cams down. Also, the two bolts by the cam seals. Thnx Alot guys!!!
Where's your shop manual?!!!
It's the best $100 bucks you'll spend on your car.
you owe me one. I'm assuming this is a B18b1
Page 6-22 in the helms
3. "reinstall the camshaft and holders. Tighten to tthe camshaft holder bolts in a crisscross pattern, begining with the inner bolts."
9.8N-m (1.0kgf*m, 7.2lbf*ft)
7.2ft lbs, tighen a 1/4 turn at a time, to ensure the rockers do not bind on the valves.
The Hayes manual says 108in lbs. I'd trust the helms over the hayes manual. I have both.
Modified by seanb18c1 at 1:28 AM 5/1/2003
EG2 SiR
Aug 31, 2003 09:03 PM
