Can you use disc brakes from 91 integra GS on 89 CRX DX?
Old Apr 30, 2003 | 12:04 PM
Norcalstoppy's Avatar
Default Can you use disc brakes from 91 integra GS on 89 CRX DX?
I'm thinking of transplanting my drivetrain from my 91 integra into a 89 CRX DX. Could I use the front and rear disc brake assembly from the integra to convert and upgrade the CRX brakes?
Jay Kim
Old Apr 30, 2003 | 12:38 PM
thenick's Avatar
Default Re: Can you use disc brakes from 91 integra GS on 89 CRX DX? (AllMotorMonster+)
for the rear you need the trailing arms and the hub, disks, lines, and PARKING CABLE.
its not necessary but suggested you pick up the proportioning valve and booster
Modified by ixiblindixi at 10:01 PM 4/30/2003
Old Apr 30, 2003 | 12:56 PM
Torino91LS's Avatar
Default Re: Can you use disc brakes from 91 integra GS on 89 CRX DX? (ixiblindixi)
For Front Use the steering knuckle, caliper, and rotor. DO NOT USE upper arm it will throw off the aligment severly. For the rear you will need entire rear trailing arm, rotor, caliper, and Parking cable from a 91 CRX SI. As for the mastercylinder and vacuum Booster, and portioning valve, they will bolt in. If you need pics or more info please let me know ok.
Old Apr 30, 2003 | 01:01 PM
thenick's Avatar
Default Re: Can you use disc brakes from 91 integra GS on 89 CRX DX? (kincaidcrxsi)
deleted my misinfo....thanks
Old Apr 30, 2003 | 02:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kincaidcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">For Front Use the steering knuckle, caliper, and rotor. DO NOT USE upper arm it will throw off the aligment severly. For the rear you will need entire rear trailing arm, rotor, caliper, and Parking cable from a 91 CRX SI. As for the mastercylinder and vacuum Booster, and portioning valve, they will bolt in. If you need pics or more info please let me know ok.</TD></TR></TABLE>
Did you notice a big difference in the braking power? I'm only gonna be making around 160whp. You think it'll be necessary?
Jay Kim
Old Apr 30, 2003 | 02:40 PM
thenick's Avatar
i think the stock size is 9.1" and the integra is 10.2"
going a full inch bigger should give you noticeably braking power. more so if you carry over the braking components from the donor car. i personally think it should perform very well for 160whp.
but thats just my opinion
Old Apr 30, 2003 | 03:53 PM
Torino91LS's Avatar
Well I live in Lousiana and wwe have a some stupid *** drivers, So I love having bigger brakes. Yes you will notice a big Fu(king difference. I'm sure u seen my mods i have listed. Yes it can handle all the whp you throw at. Remember you have a small wheel base, and a smaller car, so the brakes that are stock for a bigger car are 10x more effective on a smaller car.
Big red89
Oct 9, 2007 11:18 AM
jb0705
May 16, 2006 11:00 AM
civicguy
Nov 15, 2003 06:22 PM
nitekidsef9
Aug 27, 2003 06:00 PM
muskrat
May 28, 2003 03:46 PM
