Car smoking
Old Jul 2, 2001 | 07:34 PM
Turbohatch's Avatar
New User
Default Car smoking
Turbo ls, smoking, compression is fine, not overheating. White smoke coming out of exhaust (a lot).
Old Jul 2, 2001 | 09:11 PM
LostGsr's Avatar
Default Re: Car smoking (Turbohatch)
I believe white smoke indicate moisture condensing in the exhuast pipe if it happens only when you start it in the morning. If its happens after you warm up, check your coolant, you could be burning it. Might have a blown head gasket.
Old Jul 2, 2001 | 11:55 PM
quickLSt's Avatar
Default Re: Car smoking (LostGsr)
If the head gasket is blown, wouldn't the compression be off? Also, could this be caused if the car is running too lean? (air/fuel ratio)
Old Jul 3, 2001 | 10:02 AM
Evil DOHC's Avatar
Default Re: Car smoking (elements150)
A head gasket could be leaking into the block and the compression can still be fine. If you are puffing WHITE smoke, its most likely your headgasket. Especially if you have a sweet type of smell from your exhaust and the pipe gets moisture on the tip. I suggest you take the head off and get some arp studs with a factory honda gasket.
EVIL
Old Jul 3, 2001 | 11:13 AM
FAST94GSR's Avatar
New User
Default Re: Car smoking (Evil GS-R)
Definitely head gasket. how much are u boosting? Either torque down those bolts an extra 10-15 ft-lbs or get like evil said arp head bolts and torque that shiat down tight.
Old Jul 3, 2001 | 11:47 AM
quickLSt's Avatar
Default Re: Car smoking (FAST94GSR)
I am only boosting 6psi on all stock internals. I drove my car today and last night and the smoke has disappeared, but I don't know what it is.
benjamin
Jul 2, 2022 11:49 AM
shm91
Sep 1, 2013 03:56 AM
honda luv
Jun 30, 2009 12:05 PM
youngkow
Dec 27, 2003 12:18 PM
plastik462003
Apr 30, 2003 05:25 PM
