b16a clutch cable, can you use stock DX?
I just hooked up my clutch cable and I found that it is a little too short. the shift arm on the trans does not go all the way down now. Can I modify the old one . What did you guys do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshDM »</TD></TR><TR><TD CLASS="quote">you have to use a 91' teg cable
You dont "have" to use a teg cable. I am running a crx one. I just trimmed the rubber down a little, and it was cool. Ryan
</TD></TR></TABLE>You dont "have" to use a teg cable. I am running a crx one. I just trimmed the rubber down a little, and it was cool. Ryan
I just trimmed off some of the metal tubing with an angle grinder. then I was able to slip the bottom of the cable up so that it would be long enough. Works fine! Dont waste your money!!!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">You dont "have" to use a teg cable. I am running a crx one. I just trimmed the rubber down a little, and it was cool. Ryan</TD></TR></TABLE>
Thats exactly what i did..... just trim the rubber end peice.
jdmdude
Jun 13, 2005 07:33 AM
MapofurheadCrx
Jan 27, 2005 09:51 PM
iridebiketrials
Jul 20, 2004 02:48 PM
ironchef25
10
Jan 20, 2004 12:26 PM
