Questions RE: 1' GSR master cylinder in 96 civic
Just finish installing a 1' master cylinder and brake booster in my 96 civic. I had a question regarding one of the brake lines. It seems that one of the brake fittings doesn’t fit on the master cylinder (fitting to small). Do I need one from a GSR or si, and if so do I also need the brake line? If you guys could help I would appreciate it.
Thanks
Thanks
You only need the correct nut that screws into the MC. Pull your stock nut away from the end of the line and cut the flare off. Remove your stock nut and replace it with the correct sized nut. You will then need to get a flaring tool and reflare the end of the line.
underb00steg6
10
Mar 31, 2007 10:38 AM
JDM_EK161
May 1, 2003 07:18 AM
im_poor
Jan 18, 2003 12:24 PM
