pleas help me with tire sizes
sup guys i was planing to get some rims they are some 15" rims from a 1994 prelude and i was lookin at the tires size on my car it showed the size 195/65/15 and when i was reading about the rims it said that the tire size that are already on the rims are 205/55/15 can i fit my own tires on this rims the tires that i have on my car right now cuz the size of my own tires is 195/65/15 the prelude rims are 15"
You can use either tire but I would use the 205/55/15, wider with less sidewall
. Don't go much wider than that or you'll have clearance issues with the tire's rubbing the fender well or spring.
i just wanted to konw if i coul use my own tires that i have 195/65/15 because i bought them last month and they are brand new that's why id din't want to change them and wanted to know if i could still use the same tires with that size on the prelude 15" rims....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wont be beat »</TD></TR><TR><TD CLASS="quote">205/55-15 would be better, safer and perform better.</TD></TR></TABLE>
195 65 15=
195 65 15=
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeSH »</TD></TR><TR><TD CLASS="quote">205/60/15 would be closer to your oem size.</TD></TR></TABLE>
it's almost a perfect match
I put them on my OEM rims instead of the 195/65/15 and the speedo isn't off by a noticable ammount.
but yeah your current tires will fit the lude rims just fine.
I put them on my OEM rims instead of the 195/65/15 and the speedo isn't off by a noticable ammount.but yeah your current tires will fit the lude rims just fine.
