hydro lock vs. blown headgasket
Old Apr 30, 2003 | 06:56 AM
trbob16a's Avatar
Default hydro lock vs. blown headgasket
Like everyone else I have heard many people say they sucked up water and hydro locked their motor with a CAI.
I have now taken apart two (not many I realize) motors where the headgaskets were blown or not sealing, and the cylinders were both times FULL of water/coolant. On the cx motor there was probably a full cup on top of each piston.
I've never heard of anyone hydro-locking a motor from a blown headgasket. People blow headgaskets with F-I all the time, get water in the cylinders, and sometimes even dyno or drag the car like this without any problems. So why would sucking a small amount through an intake cause hydro-lock while a blown headgasket wouldn't?
Old Apr 30, 2003 | 07:11 AM
soundman's Avatar
Default Re: hydro lock vs. blown headgasket (trbob16a)
I think it's all about the amounts of water that get sucked into your engine. I myself have never heard of anyone getting into Hydro lock. I blew a headgasket on my eclipse so badly that the car wouldn't run because there was so much colant and water in the cylinder. I think if you were to sink your cold air intake into water and floor your car, you would get so much water that you would run into hydro lock. Personally I think the fear of Hydro lock was placed by AEM to sell those water bypass valve things.
Old Apr 30, 2003 | 07:28 AM
omahaturbocivic's Avatar
This is a long shot but maybe its because there is a hole in the gasket to push it back out.
Old May 1, 2003 | 01:42 AM
pissedoffsol's Avatar
25 Year Member
Default Re: hydro lock vs. blown headgasket (omahaturbocivic)
it happens.
here' my buddy chet's block
iceman intake... small rain fall.
boom
(sorry for the life size pic)
Old May 1, 2003 | 06:49 AM
baddassduramax's Avatar
Default Re: hydro lock vs. blown headgasket (pissedoffsol)
and that is how i got my b18b so cheap, $200 because #1 rod was bent due to hydrolock, my motor wasnt actually locked, just glad it was fixable!!
this is a pretty good link about hydrolock
http://www.prepsparkplugs.com/hydrofact.htm
Old May 1, 2003 | 08:38 AM
94TealGSR's Avatar
Default Re: hydro lock vs. blown headgasket (soundman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundman &raquo;</TD></TR><TR><TD CLASS="quote">I myself have never heard of anyone getting into Hydro lock. ... Personally I think the fear of Hydro lock was placed by AEM to sell those water bypass valve things.</TD></TR></TABLE>
hahahaha!! That's quite possibly the most asenine statement I've read in months.
Check this out...
maybe AEM photoshopped my block?
Let me know if you want full size pictures, I have 'em.
Old May 1, 2003 | 08:42 AM
Default Re: hydro lock vs. blown headgasket (94TealGSR)
how much water was in that sucker?
when i got my motor, the oil wasnt drained and it looked and had the density of light brown chocolate milk..
Old May 1, 2003 | 05:01 PM
turbolshatch's Avatar
the water that you see in the cylinders is just the stuff that comes out of the head when you pull it off. For a cylinder to hydro lock due to a blown head gasket the gasket would have to be pissing in worse then i have ever seen and i have done head jobs on cars that you can not see out the back window due to all of the smoke.
Old May 1, 2003 | 05:19 PM
trbob16a's Avatar
Default Re: hydro lock vs. blown headgasket (turbolshatch)
well in my hatch on the stock cx motor, it would overheat all the way in about 1 mile, put it this way.... when I picked it up I used 7 gallosn of water to get it home which was 6 miles away, I could NOT see out of the rear window at all
this was a first for me:
when we dropped the exhaust, water/coolant literally poured out, I mean poured not just a little
Old May 1, 2003 | 05:35 PM
Prelude Vtec 23's Avatar
Same thing happened to my girl, she bent a rod by sucking up water w/ her aem.
guy_from_nerk
Oct 14, 2008 10:57 PM
2000h22a
Jun 15, 2008 06:45 AM
Kjoram
Sep 21, 2006 07:30 AM
b20integrapower
Feb 24, 2006 05:52 PM
Hondaciv95VX
Jan 13, 2005 07:21 PM
