91 Hatch LS Swap......
Old Apr 30, 2003 | 05:01 AM
strahd_zarovich's Avatar
Default 91 Hatch LS Swap......
I have a Std Hatch and was wondering what was the easiest way to do this swap and a shopping list please. This is my first swap so any shortcut's and/or hints would be nice.
I know I have to do the DPFI to MPFI. Can I just use the Tag or Si wiring harness or would that just make thing's harder?
Thank's
Old Apr 30, 2003 | 06:53 AM
turboZChatch's Avatar
Default Re: 91 Hatch LS Swap...... (strahd_zarovich)
SI wiring harness
Hasport shift linkage
b-series mounts
Motor-b18a1
tranny-ls or gs-r or type-r a buch of options there
ecu-not sure on what the ecu code is someone else fill him in
axles-I think there 90-91 ls non abs but also not sure on these
Old Apr 30, 2003 | 07:04 AM
EF_LSVtec's Avatar
Default Re: 91 Hatch LS Swap...... (turboZChatch)
pr4 ecu... http://www.hasport.com
Old Apr 30, 2003 | 07:43 AM
raene's Avatar
I'm 90% sure you can't use the Si wiring harness, but must convert your DPFI harness to MPFI. It's not that hard to do though.
Old Apr 30, 2003 | 07:49 AM
zCivic's Avatar
Default Re: 91 Hatch LS Swap...... (EF_LSVtec)
Its a STD so you will need different hubs, 88-91 DX/SI will be good or 90-91 EX's or worse case Integras. STD/HFs use a smaller outer CV joint then other civ/tegs
Old May 1, 2003 | 05:36 AM
Default Re: 91 Hatch LS Swap...... (zCivic)
Does anyone have any helpful how-to's or web-site? or does anyone live in NC that has done this?
Old May 1, 2003 | 07:33 AM
Ben Ogle's Avatar
The latest (I think) sport compact car has an aticle on just that vey swap. Its really easy. I have it in my civic. If you go search on hybrid garage they have the wiring guide I used.
Ben
EDIT: http://www.hybridgarage.com/te...g.htm
Ryrie1995
May 21, 2016 06:52 AM
PDRIFT86
Apr 11, 2007 09:20 PM
camo_crx
Dec 20, 2005 02:34 PM
Tbindas
Jan 9, 2005 08:24 PM
b20turbojason
Oct 23, 2003 12:08 PM
