b16 swap problems...need some help
Old Apr 29, 2003 | 10:13 PM
roughrydin89's Avatar
Default b16 swap problems...need some help
i put a b16 in my 4 door civic and for some reason, it doesnt want to go into reverse...we can't even find a reverse...usually where it's at makes it go into 4th gear...need some advice on that...i even have the hasport shift linkage.................also, my car is overheating..any ideas, thermostat maybe??? let me know................and lastly, when i turn on my lights, my car dies, but if i turn them off right before it dies, it keeps running..could it be a bad ground somewhere....please help me with this...........thanks
Old Apr 30, 2003 | 06:59 AM
RCautoworks's Avatar
Default Re: b16 swap problems...need some help (roughrydin89)
The lights defiantly sounds like a bad ground, as far as not finding reverse. Maybe try putting it in first then reverse.
Old Apr 30, 2003 | 07:36 AM
raene's Avatar
Check your voltage output at idle... I have roughly 14 volts at idle on the voltmeter with the lights off, and about 13.5 with the lights on, and down to about 12.5-13 volts with the brakes on.
Old Apr 30, 2003 | 08:23 AM
Default Re: b16 swap problems...need some help (90blackcrx)
i tried the whole going into 1st, then reverse, and it doesn't work, someone told me that the shift linkage might be too short, since i have a 4 door and most people do these swaps in a hatch or crx
Old May 1, 2003 | 01:26 AM
Josho_17's Avatar
Bump
globy123
Jan 30, 2007 06:09 PM
Rob!
Jun 21, 2003 03:04 PM
roughrydin89
May 2, 2003 09:55 AM
BeeResp0nsible
Aug 29, 2002 07:24 PM
