hydro tranny with electric VSS into EF
Old Apr 29, 2003 | 05:59 PM
-DC2-'s Avatar
Default hydro tranny with electric VSS into EF
please help
to everyone with a hydro tranny in an EF....
how do i get the electric VSS to work with the EF? is it possible? i'm putting a d16y7 in a 90 civic dx auto, and we are going to use the hydro tranny. got the whole swap with 15k miles for $500. so, we have no choice but to use this tranny
the mounts and clutch issues have been figured out using custom brackets, so i don't need answers for that... just the VSS
Old Apr 29, 2003 | 07:48 PM
StorminMatt's Avatar
Default Re: hydro tranny with electric VSS into EF (DOHCDX)
Why not remove the electronic VSS and just use a regular cable drive from an eariler car? This works fine. Even if your ECU is from a 1992+ car.
Old Apr 30, 2003 | 03:32 AM
-DC2-'s Avatar
Default Re: hydro tranny with electric VSS into EF (StorminMatt)
can that be swapped in?
i doesn't even look remotely similar to the VSS housing.
Old Apr 30, 2003 | 04:46 AM
red civic standard's Avatar
when i swapped my b16 into my hatch I had to remove the electronic vss and replace it with the gear type one from my stock d-series tranny. bolted up just fine.
Old Apr 30, 2003 | 04:51 AM
-DC2-'s Avatar
Default Re: hydro tranny with electric VSS into EF (red civic standard)
SWEET!!! thanks for the info man. i'll try that tonight.
Old Apr 18, 2011 | 11:23 AM
kevmasterg's Avatar
did swapping it work?? i thought they looked very different too.
Old Apr 18, 2011 | 12:46 PM
JustOneOrTwoPosts's Avatar
I did what red civic did also. Just unbolt the 10mm bolt and pull out the entire assembly, swap it and call it a day. Dont forget to reuse the flat gear holder plate that is on the cable tranny.
nickelz34
Jul 17, 2012 08:02 PM
SiR eF_4door
Nov 13, 2009 03:16 PM
mars-EF-LS
Jul 5, 2007 08:44 PM
AJxr
May 21, 2006 07:39 PM
wadafa
Apr 23, 2003 10:12 PM
