Big Brake Kits for 4G ludes
If you want that good big brake look than it's ok to go big, but if you just want better braking, I recommend you to just go with the legend caliper upgrade. It's cheaper and also works well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedH23a1 »</TD></TR><TR><TD CLASS="quote">i like my aem big brakes... i want bigger calipers though.. stock dont bite on the entire rotor..</TD></TR></TABLE>
you can swap in the legend calipers on that kit
KVR makes a four piston caliper that is direct bolt on kit for the 4th gen. It Doesn't come with bigger rotors though, So they fit under stock rims. Great for slicks at the track or for sleepers set ups
. I got them for a steal $550, because of a miss print in an a mag last year.
http://www.kvrperformance.com
The Calipers go for $695, that's more then the legend set up, but they're 4 piston calipers!!!!!!
Modified by MindEracer at 3:11 AM 4/30/2003
Modified by MindEracer at 3:12 AM 4/30/2003
. I got them for a steal $550, because of a miss print in an a mag last year.http://www.kvrperformance.com
whitediamond642
Sep 2, 2007 12:48 AM
