bseries tranny cases?
Old Apr 29, 2003 | 12:57 PM
untitled's Avatar
Default bseries tranny cases?
are they interchangable? i have an ls tranny(90-93 integra) and i no someone who has a cable gsr tranny but the case is cracked. i was wondering if i could put the ls cases around the gsr assembly? how much work is invloled? is it easy or somewhat complicated. i am an engine guy, not a tranny guy.
Old Apr 29, 2003 | 01:00 PM
Naterror's Avatar
As long as they're both cable tranys, it will work. Just remember to swap all bearings and shims too.
Old Apr 29, 2003 | 05:47 PM
AWD: Jeff's Avatar
Default Re: (Naterror)
how much would a gsr hydro tranny case go for?
Old Apr 29, 2003 | 06:45 PM
untitled's Avatar
Default Re: (Dohc93hatch)
dont know. is their any links or anything that would help doing the transfer?
Old Apr 29, 2003 | 06:48 PM
Colin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naterror &raquo;</TD></TR><TR><TD CLASS="quote">As long as they're both cable tranys, it will work. Just remember to swap all bearings and shims too.</TD></TR></TABLE>
this is wrong! cable has nothing to do with it.
if you have a 90-91 ls then the gsr gears will NOT fit into your case. If you have a 92-93 then yes, all the internals of the gsr will fit right in, no problems. You can also put hydro gears into a 92-93 cable case.
Old Apr 29, 2003 | 06:50 PM
untitled's Avatar
Default Re: (91IntegGS)
why is this. damn it.
Old Apr 29, 2003 | 06:58 PM
Colin's Avatar
Default Re: (88crx91integra)
yeah, it sucks, i ran into basically the same problem. your best bet is to try and track down another ys1 case....but don't hold your breath they aren't all that plentiful. Another option would be to just pick up a vtec y1, j1, or s1 tranny. the nice thing about that is you wouldn't need a new clutch. 89-91 and 92+ b series clutches are different.
oh, and the task of swapping gears isn't that hard. I took apart 2 trannies over the summer and really enjoyed it. I didn't think it was hard at all. however i've talked to others who were very confused by the tranny internals and got mixed up. My main tips would be to take your time and lay out the internals in a neat and orderly fashion so as to not get things mixedup.....oh and use your manual.
Mr_Integra_93
May 16, 2008 04:43 AM
unrivaledintegra
May 25, 2007 10:39 AM
k00lt1nt
Jul 3, 2006 07:57 AM
Teal95Coupe
Feb 23, 2005 10:15 AM
schtozo
Feb 21, 2003 11:48 AM
