Swap Question :d16a6 to d15b7
Old Apr 29, 2003 | 12:17 PM
IamVtec's Avatar
Default Swap Question :d16a6 to d15b7
Okay currently i have a 91 HF with a d16a6, but im getting a free d15b7 from my friend. And i was wondering what all do i need to swap this into my car?. The reason being is because the a6 is getting up there with the miles, and the b7 only have 112k miles. So can i use the insisting wire harness? and since the motor is an obd1 , i have to use the a6 dizzy,intake manifold(fuel injectors), And Si tranny? Or can i use the b7 intake manifold with out converting obd0-1?And can i use my a6 cam gears? Any help would help out alot . THanks in advance.
Old Apr 29, 2003 | 12:51 PM
50shotRex's Avatar
Default Re: Swap Question :d16a6 to d15b7 (Full Throttle EF)
swap wiring harness over, slap the a6 manifold and dizzy over, and just plug it up
Old Apr 29, 2003 | 05:19 PM
IamVtec's Avatar
Default Re: Swap Question :d16a6 to d15b7 (50shotRex)
yo rich you talkin bout the d15 harness?
he isnt given me that though.
Old May 1, 2003 | 12:29 PM
50shotRex's Avatar
no dawg ur harness
Old May 1, 2003 | 01:31 PM
Jockobo's Avatar
also u need the drivers side motor mount from the si motor
Old May 1, 2003 | 01:37 PM
IamVtec's Avatar
ho wbout u just come and help wire it up when the motor is in
Old May 1, 2003 | 01:47 PM
redzcstandardhatch's Avatar
something different
there wouldnt be any wiring involved. just take the entire harness off the a6, take the intake manifold and distributer off the a6, put them on the d15, then put the wiring harness from the a6 on the d15. then slap your flywheel(if its different than the a6), swap your a6 tranny on it, drop it in, and drive away
Old May 1, 2003 | 05:05 PM
IamVtec's Avatar
Default Re: Swap Question :d16a6 to d15b7 (redzcstandardhatch)
Old May 2, 2003 | 02:37 PM
50shotRex's Avatar
call me when the motors are side by side i ll swap the harnesses out for u
KZK civic
Jan 10, 2012 01:46 PM
91-CRX-Si
Oct 28, 2009 09:41 PM
gnccracer20
Feb 9, 2009 10:40 PM
itRfan1
Oct 21, 2006 08:42 PM
91H4hatch
Sep 1, 2006 12:24 PM
