90 or 91 teg ecu, will it work???
Old Apr 29, 2003 | 10:24 AM
Red_Si's Avatar
Default 90 or 91 teg ecu, will it work???
instead of gettting a chip, will a 90 or 91 teg ecu provide better fuel and ignition timing maps??? I'm assuming it will because they are obd0 (correct?), if so i can probably get one for cheap, let me know
Old Apr 29, 2003 | 12:16 PM
nuc79's Avatar
Default Re: 90 or 91 teg ecu, will it work??? (Red_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_Si &raquo;</TD></TR><TR><TD CLASS="quote">will a 90 or 91 teg ecu provide better fuel and ignition timing maps???</TD></TR></TABLE>
I don't know about "better", but it will definitely be richer. The obd-0 PR-4 ECU is made to feed a dual-cam 1.8L. Your D16A6 might choke and foul plugs with that much gas...not to mention what will happen to your gas mileage I'm using an 89 Teg ECU (PG7) with my ZC, and it still runs a little rich and throws O2 sensor codes once in a while.... And the 89 teg had a 1.6 stock!
A better solution would be a SAFC/VAFC or a Zdyne SECU on your current ECU(PM6), then buy some dyno time.
But what do i know... i'm a quasi-newbie...
Old Apr 29, 2003 | 12:49 PM
50shotRex's Avatar
it works, runs hella rich, if u drive it for too long ur clothes will start to stink, but it works, i used it at the track on my stock d16a6, ran a 15.7@88
92BluEH-3
Jan 12, 2008 12:15 PM
Wes90civic
Jun 17, 2006 02:39 PM
CBURKE
Aug 26, 2005 01:10 PM
stevescivic
Feb 4, 2005 05:38 PM
bc_psychocivic
11
Jul 10, 2003 08:07 AM
