Turbo Kit From Domestic
Old Apr 29, 2003 | 09:52 AM
darylfiend11's Avatar
Default Turbo Kit From Domestic
Is it possible to take a turbo off a 1988 ford thunderbird turbo coupe and put it on my 92 honda prelude si h23a1? If so will it take alot of work? From a mechanic that would be advanced and knows what he is doing?
Old Apr 29, 2003 | 11:42 AM
papa_smurf's Avatar
Default Re: Turbo Kit From Domestic (darylfiend11)
i dont know too much in the way of turbos but if you were just trying to use the turbo the hardest part would be trying to find a exhaust manifold to bolt up to it, i dunno what kidna turbo ford thunderbirds used tho so.. it might be difficult to source one.
Old Apr 29, 2003 | 11:46 AM
TRN's Avatar
TRN
it will probably take a bit of custom fab work...but anyone who's got the skills should be do it with a little creativety...and if your willing to spend some $ too of copurse.
Old Apr 29, 2003 | 12:24 PM
prelittlelude's Avatar
Default Re: (TRNRacer)
yes its possible, i am in the middle of making a custom kit, out of all the junkyard turbos the one off the thunderbird should flow enough on our engines for a 6.5 to 7psi boost setup. Ive wanted to boost and im planning on using one of these turbos with a revhard mani . the thunderbirds have a t3 in them. good luck
Old Apr 29, 2003 | 12:48 PM
Default Re: (prelittlelude)
would it be cheaper to do it this way or to buy a bolt on kit and what is the price range for both?
Old Apr 29, 2003 | 04:50 PM
TrboH22's Avatar
by the time you buy some fuel management, and have custom pipign made, I htink you'd be betetr of spending the extra $$ on a proven turbo kit with quality parts. You get what you pay for.
Old Apr 30, 2003 | 07:46 AM
Default Re: (jz)
got any pics of that setup? .. But yeah i agree with jz, you can make an ok kit for around a grand that should work just fine. I mean many will disagree and say that its never going to be as good at a direct fit kit, but doing a junk yard setup is a good place to start esp if you don't know if boost is worth the $
DC2 BoZz
12
Sep 25, 2004 06:39 PM
egzo04
Sep 14, 2004 06:39 PM
2fastcivic
Jun 18, 2004 05:48 PM
Nextelbuddy
Jun 9, 2003 02:21 PM
phatridinDus10
Jan 26, 2002 09:58 AM
