Suspension technique sway bars.
Old Apr 29, 2003 | 09:25 AM
Bases's Avatar
Default Suspension technique sway bars.
I have a problem with my front sway bar, it seems to be squeeking and knocking. Does anybody have a clue what is causing this, or how I can fix it...
Thanks in advance.
Old Apr 29, 2003 | 11:05 AM
litlekikr's Avatar
Default Re: Suspension technique sway bars. (EK9Grander)
if it came w/ poly bushings, you may not have greased them enough, as far as the knocking, double check all the bolts and make sure nothing is loose. Jack the car up and load the suspension w/ another jack and see if it hits something
Old Apr 29, 2003 | 11:48 AM
Bases's Avatar
Default Re: Suspension technique sway bars. (litlekikr)
Thanks...
Old May 2, 2003 | 11:24 PM
9civic5's Avatar
Damn Jay, probs already?
Old Jan 15, 2004 | 12:33 PM
90civichbsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litlekikr &raquo;</TD></TR><TR><TD CLASS="quote">if it came w/ poly bushings, you may not have greased them enough, as far as the knocking, double check all the bolts and make sure nothing is loose. Jack the car up and load the suspension w/ another jack and see if it hits something</TD></TR></TABLE>
as far as i know you arent supposed to grease sway bar bushings
Old Jan 15, 2004 | 12:42 PM
1's Avatar
Default Re: Suspension technique sway bars. (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">
as far as i know you arent supposed to grease sway bar bushings</TD></TR></TABLE>
Please tell me you are joking.
Old Jan 15, 2004 | 12:44 PM
SoulSurfer's Avatar
Do you know why? I grease all bushings.
Old Jan 15, 2004 | 12:47 PM
1's Avatar
Default Re: Suspension technique sway bars. (SoulSurfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoulSurfer &raquo;</TD></TR><TR><TD CLASS="quote">
Do you know why? I grease all bushings.</TD></TR></TABLE>
He said 'as far as I know' which isn't that far.
Bases, make sure all the mounts are torqued and all the bushings lubricated.
Old Jan 15, 2004 | 06:40 PM
hughesl's Avatar
Default Re: Suspension technique sway bars. (Bases)
After one season my st rr swaybar made clicking noises. It is coming from the spherical bearings. They are already worn out. I am going to replace them with some better quality ones. It is worth a look.
Rob.
Suspension & Brakes
20
Nov 27, 2006 09:20 PM
coot_er
Jul 18, 2006 04:12 PM
rossockr
May 10, 2004 12:30 PM
ej0513
Sep 23, 2003 06:40 AM
