reason for REALLY bad tire wear? pics
Old Apr 29, 2003 | 07:50 AM
bullet9925's Avatar
New User
Default reason for REALLY bad tire wear? pics
http://www.nd.edu/~anakamot/000_0007.JPG
http://www.nd.edu/~anakamot/000_0008.JPG
Those are pics of my back left and right tire i got on the way to shool after christsmas break. I had 2 duffel bags and stuff in my backseat that was kinda heavy. my car is lowered 1 inch and i have pirelli p7000 supersports on 18inch axis sevens. The 2 front tires were perfectly fine and still had like 60 percent tread on them. I have no idea why just the back ones did it! Is it the weight in the trunk and backseat?
Does anyone have any idea why this would have done this. A couple of people have said that I need a 4-wheel alignment. I had one done during the summer before school started. (maybe they did a shitty job?)
Any help would be greatly appreciated!
Old Apr 29, 2003 | 07:56 AM
laughinxxx's Avatar
New User
Default Re: reason for REALLY bad tire wear? pics (bullet9925)
The alignment looks pretty good.
That extra wear down the center of the tire was caused by excessive tire pressure.
Old Apr 29, 2003 | 08:10 AM
Xlerate9's Avatar
Yup looks like they were over inflated. Did u get an alignment after you lowered it?? It looks like you have slight negative camber (normal for a 1 inch drop) and maybe your toe was way off. I'd def go get an alignment when you get new tires.
Old Apr 29, 2003 | 09:49 AM
KENLUDE97's Avatar
Default Re: reason for REALLY bad tire wear? pics (Xlerate9)
Nothing looks seriously wrong with that tire wear, other than they were/are on the car about 3000+ miles too many!! You may need a minor alignment. And that wear pattern is showing like others said HIGH air pressure.
Old Apr 29, 2003 | 01:17 PM
577HondaPrelude's Avatar
Default Re: reason for REALLY bad tire wear? pics (KENLUDE97)
yup, looks like pressure was a bit too high. Did only the back tires wear out? did you say the front ones were fine? Did you ever rotate them?? Wierd that your back would wear faster than your front. You might have some bad toe in/out in the rear causing them to wear faster than front.
Old Apr 29, 2003 | 04:04 PM
Slatelude's Avatar
Default Re: reason for REALLY bad tire wear? pics (57STS)
Definately a overinflation problem....and probably tow end not set right. That'll eat your tires faster than a fat lady in a candy store. I had to slightly modify my tow arm to be able to get it aligned correctly....but then again I'm runnin' Eibach Sportlines 1.5+ drop.
Kevin
Old Apr 29, 2003 | 05:42 PM
kb58's Avatar
Banned
Default Re: reason for REALLY bad tire wear? pics (Slatelude)
That's Toe, T-O-E, not tow, like in truck.
Old Apr 30, 2003 | 08:40 AM
bullet9925's Avatar
New User
Default Re: reason for REALLY bad tire wear? pics (kb58)
Yeah it was weird, just the back ones did that. I had them rotated about 4 thousand miles before this happened.
How do you fix the toe. Is that what a canber kit does? I thought I really don't need one on a 1 inch drop.
Old Apr 30, 2003 | 08:48 AM
bryan305's Avatar
Actually, if it's just the one spot on each of your rear tires that is worn like that, I'd say it was caused by 2 things: 1.) overinflation caused the center of the tires to wear faster ALL THE WAY AROUND. 2.) That single wear spot was caused by either locking up the rear and sliding, or driving with your e-brake on. That's the only way to have just one spot on the rear tires be worn that much more than the rest...unless I'm missing something
Old Apr 30, 2003 | 08:50 AM
RAB's Avatar
RAB
Default Re: reason for REALLY bad tire wear? pics (laughinxxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laughinxxx &raquo;</TD></TR><TR><TD CLASS="quote">The alignment looks pretty good.
That extra wear down the center of the tire was caused by excessive tire pressure. </TD></TR></TABLE>
Bingo and I ditto that.
Old Apr 30, 2003 | 09:40 AM
bullet9925's Avatar
New User
Default Re: reason for REALLY bad tire wear? pics (RAB)
thanks alot everyone. I am going to get a 4-wheel alignment today. What do you think i should have the tire pressure at? I got 4 new tires and I think the pressure at 40 right now, should i lower it to maybe 35?
thanks again
Old Apr 30, 2003 | 10:25 AM
tec-9-7's Avatar
I think the recommended inflation pressure is like 32 psi. Try that. It also looks like a little excessive wear to the inside, so I'd try to get the toe zeroed...
Paul
Old Apr 30, 2003 | 02:21 PM
Default Re: reason for REALLY bad tire wear? pics (tec-9-7)
34psi in front
31psi in back
Works good for even wear for street driving on my prelude
SiiiAlbert
Oct 25, 2013 03:02 PM
SI_you_later
Honda Civic (2006 - 2015)
14
Aug 23, 2007 06:28 AM
SOHCMAN
Jan 15, 2004 08:11 AM
Chris N
Jun 17, 2003 07:18 AM
GRM Scott
Oct 25, 2001 11:53 AM
