exhaust cam wires
Old Apr 29, 2003 | 07:48 AM
zccrx's Avatar
Default exhaust cam wires
which wires do i connect to the exhaust cam sensor on the zc. it was a dx to zc swap just in case it matters
Old Apr 29, 2003 | 09:39 AM
RuffRhyno's Avatar
Default Re: exhaust cam wires (zccrx)
Run the blue/green wire from pin C1 (which you moved the original wire to B10), and the blue/yellow wire from pin C2 (which you moved the original wire to B12). These are for the cylinder position sensor that is located on the exhaust cam.
QuickStyle
Feb 10, 2007 06:57 PM
efcivic757
Oct 3, 2004 07:46 AM
I8ayellowcrayon
May 24, 2004 08:21 PM
SiRWannabe
Apr 29, 2003 06:01 PM
cr-x si
Mar 1, 2003 02:35 PM
