Does the rear seat carpet attach to the inside of the car with the seat removed?
Old Apr 29, 2003 | 06:33 AM
TypeR-R6's Avatar
Default Does the rear seat carpet attach to the inside of the car with the seat removed?
Just wanted to know if I take out my rear seats does the carpet that is attatched snap into the floor board. Thanks.
Old Apr 29, 2003 | 06:38 AM
Floyd's Avatar
Default Re: Does the rear seat carpet attach to the inside of the car with the seat removed? (TypeR-R6)
I'm not sure what you mean. If you are talking about the trunk carpet, which is attached to the back of the rear seats, then no, it will come out with the seats.
Old Apr 29, 2003 | 06:43 AM
TypeR-R6's Avatar
Default Re: Does the rear seat carpet attach to the inside of the car with the seat removed? (Floyd)
Yea the rear trunk carpet is fastened to the seat with push pins but if i unfastened it from the seat can I lay it down and fasten it to where the bottom of the rear seat is?
Old Apr 29, 2003 | 06:47 AM
Dave-ROR's Avatar
you can remove it from the seat backs and lay it down pretty flat.. not sure if you can attach it where the floor carpet attaches or not though.. sorry. it's quick and easy to answer your own question though.
Old Apr 29, 2003 | 06:48 AM
Mugen Mike's Avatar
There is nowhere to "snap" it in place. I bought some velcro and attached the velcro to the plastic strip along the top of the carpet. Stays in place fine with the velcro, otherwise the carpet will flap around with the windows down.
Old Apr 29, 2003 | 06:49 AM
io_burn's Avatar
New User
Default Re: Does the rear seat carpet attach to the inside of the car with the seat removed? (dawhiteboy)
What about some of that heavy duty super sticky velcro? Put some on the bare metal where the seats were removed, and some on the other side of the carpet, that way you can not have floppy carpet and still have it be backwards compatible if you ever put your seats back in.
Edit: ****, beaten.
Old Apr 29, 2003 | 07:08 AM
TypeR-R6's Avatar
Default Re: Does the rear seat carpet attach to the inside of the car with the seat removed? (io_burn)
Thanks for the replies. I would have tried it before asking but I'm at work and my mind is wandering thus the reason for the question.
Old Aug 17, 2007 | 03:20 AM
:jdmshmaydm:'s Avatar
Back from the dead...
Does anyone know the part number for the push pin black caps that hold the carpet to the back seat? How many are there total on each side?
Old Aug 17, 2007 | 04:58 AM
jgirard's Avatar
Default Re: Does the rear seat carpet attach to the inside of the car with the seat removed? (:jdmshmaydm:)
http://www.sonsacuraparts.com/...ch=no
^ Check here
Old Aug 17, 2007 | 05:19 AM
JjuuN R's Avatar
Default Re: Does the rear seat carpet attach to the inside of the car with the seat removed? (jgirard)
Having a new rear carpet made with out any holes or slits in them.
Old Aug 18, 2007 | 03:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgirard &raquo;</TD></TR><TR><TD CLASS="quote">http://www.sonsacuraparts.com/...ch=no
^ Check here</TD></TR></TABLE>
thank you!
SOHCVTEC
Honda CR-V & Element
Mar 24, 2018 02:25 PM
Driver
Aug 3, 2011 10:16 PM
LoNgHoRn
Jan 18, 2007 01:31 AM
LindaOz
Feb 6, 2005 04:39 PM
magic hat #9
Dec 24, 2002 06:40 PM
