rear camber with spacers?
im trying to get some more camber in my rear tires and im to cheap to bye a camber kit so im gonna use spacers on the upper control arm..This a good idea and about how many spacers should i use?? i heard alot of people do it for a cheap fix so what do you guys think??
i am dropped about 2-2.25 inches in the back. and i put 2 washers per screw.. and tis very close to be 0 camber.... ill say put 2 and that should be good enough
Do you want to stand the tire up straighter (more vertical) or do you want more camber (tipped in more at the top). The washers will push the top of the wheel out, giving less camber, but more tire life.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russian_racer »</TD></TR><TR><TD CLASS="quote">What about the front ...were do you put the washers in the front????</TD></TR></TABLE>
well i broke down and bought a front camber kit, but decided spacers behind the bolts will be good for the back..and yes i want the top of the tire farther out, giving the tire a straighter look, and better tire wear..2washers sound about right..thanks
thehondabuddy
May 17, 2003 01:44 PM
