4th Gen Lude SRS light
Old Apr 28, 2003 | 06:08 PM
mdjplay's Avatar
Default 4th Gen Lude SRS light
My SRS (supplemental restraint system) light has suddenly started going crazy on me. It has no pattern to it but blinks on and off constantly as Im driving now... its irriating as hell! Anyone had this prob, know how to fix it or what is causing it? Any suggestions besides cutting it? Thanks!!
Old May 5, 2003 | 04:33 PM
Chinchilla's Avatar
Default Re: 4th Gen Lude SRS light (mdjplay)
Just wondering if you figured it out... mine is doing the same thing right now. I took the steering column apart and fiddled with the connector and it seems that the light goes on and off but I can’t really find the root of the problem... the connector is plugged in but its almost like something is loose in side causing the light to come on when I go over bumps.
Old May 5, 2003 | 04:49 PM
JG Luder's Avatar
Default Re: 4th Gen Lude SRS light (Chinchilla)
check your ECU for a code and see what it says.
Old May 5, 2003 | 04:58 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: 4th Gen Lude SRS light (Lone Luder)
1) disconnect battery
2) remove trim panel around guage cluster
3) remove guage cluster
4) remove SRS light bulb
5) repoeat steps 1-3 in reverse order
Old May 5, 2003 | 05:03 PM
JG Luder's Avatar
Default Re: 4th Gen Lude SRS light (Boosted97Lude)
can't do that on a 4th gen. It's slightly more complicated cause our dash is from a friggin space ship.
Old May 5, 2003 | 05:05 PM
Boostless97Lude
Guest
Posts: n/a
damn it, that's right, you've got the super "we are the future" spaceship all the way acros the dash guages WTF, that's not normal
Old May 5, 2003 | 05:14 PM
stockludesi's Avatar
usually when the srs light flashes on and off. it means that the srs system is malfunctioning. taht there is some error in the system. i would pull out your chiltons manual and look through it to see if you can run a diagnosis of the problem
Old May 6, 2003 | 05:26 PM
Chinchilla's Avatar
Default Re: 4th Gen Lude SRS light (stockludesi)
no its not flashing... its"flickering" there is not pattern to it and I know that the harness is the problem I just dont know why. if I hit the steering column with with my fist it will shut off until I got over the next bump.... I'm going to pull it apart this weekend and see if I can yank the bulb
oh and I do have a helms manual, its no help right now
Old May 6, 2003 | 05:35 PM
JG Luder's Avatar
I'd get into the system itself.
Check the connections on the srs computer (behind teh radio with all the yellow wire loom coming off of it)
check the steering wheel connections. Pull the bag out (you'll need a torx set) and check the connection on it.
if it truely is loose, why risk having the bag get a whack signal and blow up in your face?
Old May 6, 2003 | 08:16 PM
BoostedH23a1's Avatar
reset it.... there is a sequence to do it... look at All Data or Michell (sp?) they have step by step process.
Old May 6, 2003 | 08:21 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: 4th Gen Lude SRS light (BoostedH23a1)
and if you check the connections, BE SURE TO DISCONNECT THE BATTERY FIRST AND WAIT AT LEAST 2 MINUTE FIRST!!!
just need to give you that very importtant info
Old May 6, 2003 | 09:33 PM
Que_Lude's Avatar
There is also an SRS relay in the fuse box. Not sure if this has a relationship with your prob.
sshp
Apr 5, 2006 11:17 AM
im a monster hehe
Oct 11, 2004 05:48 AM
Taikonaut
Sep 27, 2003 07:46 AM
rjr162
Mar 16, 2003 05:59 AM
