Will a 5-lug w/ abs have problems on a non-abs car?
Old Apr 28, 2003 | 06:04 PM
Propulsion's Avatar
Default Will a 5-lug w/ abs have problems on a non-abs car?
A couple of questions:
1. Do JDM ITR's have abs?
2. Will I encounter problems adapting a 5-lug setup w/ abs on a 96 civic w/o abs?
Old Apr 28, 2003 | 06:10 PM
DaiJekBok's Avatar
Default Re: Will a 5-lug w/ abs have problems on a non-abs car? (SilverCIVIC96)
The only difference in the pieces you're going to be using is the presence of the ABS ring on the axles.. it's an aluminum ring with squared-off bumps on it that the wheel speed sensor "reads" to determine each wheel's speed relative to the others. I'm 99% sure you can leave these on for a non-ABS car, but I am 100% sure they pop right off with a few light whacks with a well-placed flathead screwdriver and hammer.
Old Apr 28, 2003 | 06:40 PM
ChiBoy's Avatar
I installed an ABS 5-lug on my EG and had no problems at all. I just removed all of the sensors. The rears are a no brainer, but I don't know for sure about the fronts. My axles did NOT have the abs ring and worked fine with the abs front knuckles.
Don't know about the 96, but it worked fine with a 93.
Old Apr 29, 2003 | 04:38 AM
Bontke's Avatar
Default Re: Will a 5-lug w/ abs have problems on a non-abs car? (ChiBoy)
Since you don't have ABS, your car isn't looking for any ABS signals. ONly time you would have a problem is if your car was looking for a signal and not getting it.
GI8U2racing
Aug 16, 2011 07:37 AM
josh-roy
Jul 30, 2010 02:32 AM
siblue_gzer
Aug 13, 2007 12:17 PM
Propulsion
Apr 29, 2003 05:55 AM
NorthernXposure
Mar 25, 2002 05:28 AM
