problems with 93 accord auto->standard H22 swap NEED HELP,Won't Start
Old Apr 28, 2003 | 04:07 PM
FBTuning's Avatar
Default problems with 93 accord auto->standard H22 swap NEED HELP,Won't Start
93 accord ex, was an auto, now changed to standard with an H22, used accord EX harness modified with the extras (vtec sol, vtec pres, knock), changed the backup lights to a standard, and wired in a relay off the added clutch switch to work the starter solenid, all the added stuff and stuff we've changed so far works, we've got power going to all 3 wires on the coil (stock external coil) adn one on the ignitor, problem is it'll turn but I get no spark whatsoever, I've looked through everythign and cannot find the problem, I'm sure someone has doen this before, and has had this same problem, so if anyone has anyideas of what else I need t run, check, or tap into I'd relaly appreciate it, cus that's the only thign stopping me from running
HatchbackFreakEK
Mar 2, 2009 07:17 AM
93accdcivickla
Jul 24, 2007 10:32 PM
conceptEG
Aug 3, 2004 04:24 AM
ricekiller1
Feb 26, 2004 11:25 AM
