code 41 being thrown in 00 civic hatch, how to fix
Old Apr 28, 2003 | 03:37 PM
Shark Tank's Avatar
Default code 41 being thrown in 00 civic hatch, how to fix
code 41 being thrown...this is what honda says it is
Primary Oxygen Sensor - Heater circuit malfunction
whats the easiest way to fix this...gas mileage per gallon has gone to **** since this code has come on
Old Apr 28, 2003 | 04:33 PM
Chiovnidca's Avatar
Default Re: code 41 being thrown in 00 civic hatch, how to fix (Shark Tank)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shark Tank &raquo;</TD></TR><TR><TD CLASS="quote">code 41 being thrown...this is what honda says it is
whats the easiest way to fix this...gas mileage per gallon has gone to **** since this code has come on</TD></TR></TABLE>
Do you want to make sure what the problem is or do you just want to throw an o2 sensor at it?
Old Apr 28, 2003 | 06:14 PM
Jonathan_ED3's Avatar
Default Re: code 41 being thrown in 00 civic hatch, how to fix (Chiovnidca)
I'm throwing 41 too.
Wiring is all good, and it's a brand new o2 sensor...
Hopefully another new o2 will fix it.
Shark Tank's Avatar
either i have the time and probably have the tools
Old Apr 30, 2003 | 11:19 AM
JimBlake's Avatar
The heater circuit is 12v supply to the heater leads of the sensor. Got a DMM? It's just a 12v dc circuit with a resistance heating element built into the sensor. Code 41 has nothing to do with the oxygen sensing element itself.
Check to see if the heater has continuity. Check the Helm book to see what resistance it's supposed to have. If OK, then check to see if the harness is supplying 12v power to the heater. If not, then look for blown fuses or busted wires.
kuks24
11
Jun 24, 2019 04:59 AM
Keeper1343
Oct 25, 2007 01:56 PM
SONIC BOOM
Jun 23, 2006 06:40 AM
HYBRIDHATCH92
Aug 15, 2002 03:52 PM
YaMaJeSty
Jul 26, 2002 04:01 AM
