96 ex intake manifold
Old Apr 28, 2003 | 08:21 AM
crashtest Sonny's Avatar
Default 96 ex intake manifold
is there an air temp sensor on it? i have a check engine light, and the plug is not hooked..and i need to do smog.
Old Apr 28, 2003 | 10:38 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: 96 ex intake manifold (4g_civic_si)
no...you have to put an IAT sensor in your intake line somewhere.
heres a pic of how i did mine:
https://honda-tech.com/zerothread?id=461235
Old Apr 29, 2003 | 12:24 AM
Default Re: 96 ex intake manifold (fastcrxsi90)
did you just poke a hole through that intake rubber thing to make that sensor? what about the red tube from the charcoal canister?
Old Apr 29, 2003 | 07:10 AM
zCivic's Avatar
are you speaking of the large red tube???On a A6 it would go on the T/B right?? It should have a spot in the front of the mani where you can extend the hose and run it to it....
Old Apr 29, 2003 | 08:55 AM
Default Re: 96 ex intake manifold (zCivic)
ya that big red tube. theres nothing on the manifold. everything that needs to be plug on the manifold is plugged.
Old Apr 29, 2003 | 09:55 AM
zCivic's Avatar
Theres 2 large ones on the front side. One is for the PCV valve to the catch can the other one you can run to that red hose....
Old Apr 29, 2003 | 10:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g_civic_si &raquo;</TD></TR><TR><TD CLASS="quote">did you just poke a hole through that intake rubber thing to make that sensor? what about the red tube from the charcoal canister?</TD></TR></TABLE>
yeah...i know its ghetto...but it works fine and id rather do that then chop up my CAI trying to get it to work.
the red tube is for the canister...its a B18A TB so it is setup just like the A6 TB...makes thing easier and is 2mm bigger than the Y8 TB (3mm bigger than A6)
Old Apr 29, 2003 | 10:54 AM
if you get a bigger TB..does that mean you have to change the ecu for more fuel to even it out? how much does a TB cost..? where did you get the sensor from? thanks.
Old Apr 30, 2003 | 07:34 AM
for all the y8 owners, i would like to know where you guys plugged the IAT sensor to.
VTECinWOT
Oct 24, 2011 05:27 AM
andreysibiris
Jan 16, 2006 04:31 PM
tony n.
Jun 29, 2005 09:28 PM
Stoich EG2
Dec 15, 2004 11:27 AM
Onoerhime
Oct 6, 2004 09:17 AM
