How to do auto transmission fluid change?
Old Jul 1, 2001 | 10:36 PM
99ls's Avatar
Default How to do auto transmission fluid change?
How do I change the ATF on my car? Does it need to be performed by a pro or is it okay to change it in the garage?
Also, any reccomendatoins for what ATF I should use?
Old Jul 2, 2001 | 08:09 AM
96IntegraLS4DR's Avatar
Default Re: How to do auto transmission fluid change? (99ls)
Simple drain and fill will replace 1/2 of your ATF or about 3 Qrts.
The drain bolt is located on the passenger side.
It has 3/8 square hole in the middle and the tool to open it is 3/8 rachet.
Like Teken said, shop can replace all ATF with a pump that looks somthing like this: http://www.motorvac.com/TRANSTECH/transtech.html
As for what kind of fluid - you can use Honda ATF Z-1 or Mobile 1 synthetic ATF.
Good Luck.
hawks85
20
Jul 19, 2017 03:33 PM
AlienKrOZ
Oct 5, 2006 04:50 PM
JMD
May 8, 2003 10:28 AM
Ronin Integra8
Dec 12, 2002 01:13 PM
illusion
Mar 4, 2002 07:54 AM
