is the antennae on the new accord really the defroster?
Old Apr 28, 2003 | 12:40 AM
ILOVEGIRLS's Avatar
Default is the antennae on the new accord really the defroster?
is this true? is the new accord radio antennae in the defroster lines?
Old Apr 28, 2003 | 01:02 AM
Kamin's Avatar
Default Re: is the antennae on the new accord really the defroster? (ILOVEGIRLS)
its been like that for a while
my moms 2000 had that.
Old Apr 28, 2003 | 08:58 AM
martini's Avatar
Default Re: is the antennae on the new accord really the defroster? (Kamin)
My FD RX-7 has a seperate AM antenna in on the back window. It's not the same line as the defroster..but it's back there.
Old Apr 28, 2003 | 02:25 PM
ILOVEGIRLS's Avatar
Default Re: is the antennae on the new accord really the defroster? (martini)
hmm..anyone else?
Old Apr 28, 2003 | 02:28 PM
liquid51's Avatar
My 89 prelude has a second antennae above the defroster lines that works in conjunction with the mast on the rear quarter panel. The factory radio recieves both signals, and then switches back and forth between the two, depending on which is stronger.
Old Apr 28, 2003 | 04:10 PM
DaiJekBok's Avatar
My TL has the antenna integrated in the rear window as well. Look at the headliner in the rear of the car where it meets the upper portion of the rear window glass. You'll see a small plastic "box" protruding -- that contains the leads for the antenna.
Old Apr 28, 2003 | 04:26 PM
Stew Pidasso's Avatar
Default Re: is the antennae on the new accord really the defroster? (DaiJekBok)
My 94 Accord has the antenna integrated into the rear window but the actual antenna part is separate...
Old Apr 28, 2003 | 04:30 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILOVEGIRLS &raquo;</TD></TR><TR><TD CLASS="quote">is this true? is the new accord radio antennae in the defroster lines? </TD></TR></TABLE>
They are two seperate grids.
Old Apr 28, 2003 | 05:16 PM
b19coupe's Avatar
Can you imagine the static on AM with the defroster on if they used the same wire? There are two separate grids, as stated by a couple of people above.
Old Apr 28, 2003 | 09:32 PM
ILOVEGIRLS's Avatar
Default Re: is the antennae on the new accord really the defroster? (b19coupe)
i see..thanks. also, the TL's..are their antennaes on the roof?
tjjm36m3
Mar 10, 2009 08:34 AM
tjjm36m3
Mar 3, 2009 01:43 PM
accorddog
Dec 17, 2008 12:20 PM
stealthmode62
Apr 4, 2008 08:45 AM
phateless
Jan 22, 2003 09:02 AM
