HELP with my b16 swap in a 91 crx si!!!!!!!!!
Old Apr 27, 2003 | 10:21 PM
groovinmind's Avatar
Default HELP with my b16 swap in a 91 crx si!!!!!!!!!
ok folks, heres my problem, ............ ok i droped in the b16a1 setup i had in a 91 crx si, everythign is all pluged up except for a white plug thats right near the alt, like you have the alt plug then theres also a little white plug.. its a male, the female part would be the same part as the female of the vtech solenoid,..please help ahhhhhhhh, also im havin trouble gettin the little pin out of the shift linkage.. any suggestions i was poundin like a mad man it wont come out so i can put my b hastport linkage on... any help would ne apriciated
Old Apr 27, 2003 | 10:31 PM
Jonathan_ED3's Avatar
Default Re: HELP with my b16 swap in a 91 crx si!!!!!!!!! (groovinmind)
the 'bitch pin'
I always get it out using a Pin and a Hammer.
Also, PB Blaster or whatever it's called works wonders!
Old Apr 28, 2003 | 05:41 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by groovinmind &raquo;</TD></TR><TR><TD CLASS="quote">also im havin trouble gettin the little pin out of the shift linkage.. any suggestions i was poundin like a mad man it wont come out so i can put my b hastport linkage on</TD></TR></TABLE>
You should've removed it with the motor/tranny out of the car, it's much easier that way. But since it's in, you need an 8mm punch to beat it out. You might need to heat it up a little with a torch because older ones can sieze up.
the_rex
Mar 3, 2008 05:46 AM
b17turbo
May 21, 2006 11:13 AM
SpeedDreamz.com
Dec 31, 2003 12:13 PM
Just Checking In
Oct 12, 2003 07:17 AM
