HELP!!!....with wiring!! (DX-Si)
Old Apr 27, 2003 | 07:34 PM
Broken Gearbox's Avatar
Default HELP!!!....with wiring!! (DX-Si)
hey everybody my friend just installed a D16a6 motor in his 91 DX and were having trouble getting the bitch started...which wiring harness would be easier to use..the dx or the si??...cause we have both..also what does this mean..
"cut wires A3(yellow) and A7(red), although leave some wire for later use. Now run wires from pins A3 and A7 into the engine compartment and label them. "
does that mean we have to run two extra wires from the ecu threw the firewall onto the injectors?...we havent done that yet but shouldn't the car still start even though all the injectors arent connected properly??..cause when we try to crank the car it doesnt get any spark...im sure its getting fuel cause you can smell it..so maybe the dist is fucked???...but when he got the motor from the guy it was still in his car..so i guess it should be working fine. so any help would be appreciated also if anyone from the bay area has any extra time to help us we would really aprreciated thanks.
Old Apr 27, 2003 | 11:05 PM
philly-O's Avatar
Default Re: HELP!!!....with wiring!! (s_o_h_c)
you extend 4 wires into the engine bay, the blue/yellow and blue/green to the distributor and a yellow and red for the other 2 injectors. search on this topic cause there is a killer wiring diagram someone made up. goodluck man
Old Apr 28, 2003 | 05:31 AM
white99gsr's Avatar
Default Re: HELP!!!....with wiring!! (peichie)
you take the ENGINE side of the cut wires and run them to B10 and B12, then take the ECU side of the cut wires and run them into the engine bay.
Old Apr 28, 2003 | 05:41 AM
Hondasaurs's Avatar
The engine must have a modified DX harness on it. You will need the 4 Si injectors and the Injector resistor box. Only 4 wires run to the engine bay from the ECU. 2 fuel injector wires and B10 and B12 go to the distributer or exhaust cam on a ZC swap.
Old Apr 28, 2003 | 06:33 AM
Louie B.'s Avatar
Default Re: HELP!!!....with wiring!! (ZC_CRX)
Old Apr 28, 2003 | 09:53 AM
Ronin Panda's Avatar
will i need 4si injectors and the injector resistor box for my ZC swap even if the ZC comes with injectors? im pretty sure it will come with injectors so will i still need the si injector resistor box?
Old Apr 28, 2003 | 02:54 PM
Default Re: HELP!!!....with wiring!! (Touge Panda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touge Panda &raquo;</TD></TR><TR><TD CLASS="quote">will i need 4si injectors and the injector resistor box for my ZC swap even if the ZC comes with injectors? im pretty sure it will come with injectors so will i still need the si injector resistor box?
yea your gonna have to use the si resistor box...also thanks everyone for the help
ryanevansoh
Mar 27, 2009 04:06 PM
90jdmcrxdude
12
Jul 8, 2006 10:11 AM
HBK
13
Jul 18, 2005 09:36 PM
importboi22
May 31, 2004 02:31 PM
geoff19crx
May 31, 2003 08:19 AM
