What can cause low RPM detonation?
Old Apr 27, 2003 | 06:13 PM
jonnybravo's Avatar
Default What can cause low RPM detonation?
I'm getting low RPM detonation while under load. Any idea on why? I checked my plugs and they look good.
Old Apr 27, 2003 | 06:14 PM
Phoenix_ITR's Avatar
Default Re: What can cause low RPM detonation? (jonnybravo)
is your timing still at stock specs?
-tony
Old Apr 27, 2003 | 06:26 PM
jonnybravo's Avatar
Default Re: What can cause low RPM detonation? (delinquent)
No, it's advanced to 18 degrees and is fine tuned by Hondata.
Old Apr 27, 2003 | 07:10 PM
00 FBP ItR's Avatar
retard the timing, or higher octane..
are you sure its dentonation?
Old Apr 27, 2003 | 07:18 PM
jonnybravo's Avatar
Default Re: What can cause low RPM detonation? (00 FBP ItR)
Not 100% but it sounds like it I think. It sounds like rocks in a coffee can however it sounds like it's coming from below. Could it be my testpipe?
Batoutahell's Avatar
Bad detonation will be visible on your spark plugs. If they look okay, maybe you're hearing something else. Can you describe the sound?
Old Apr 27, 2003 | 07:45 PM
jonnybravo's Avatar
Default Re: What can cause low RPM detonation? (Batoutahell)
Sounds like rocks in a coffee can from 3000 to 4500. How will the detonation look on the plugs? I think they looked nowmal. Maybe a little white.
Old Apr 27, 2003 | 07:53 PM
Well, when I describe what detonation sounds like, I say it's like rocks in a coffee can. Moderate detonation will leave "freckles" on your spark plug. Violent detonation will cause physical damage the plug. If your problem is detonation, I'd be more concerned about detonation in the upper rpm's where you can't hear it.
Do you know what your air/fuel map looks like?
Old Apr 27, 2003 | 08:06 PM
jonnybravo's Avatar
Yea...Here's my dyno sheet. Blue line.
http://www.imagestation.com/pi...g.jpg
Old Apr 27, 2003 | 08:41 PM
00 FBP ItR's Avatar
maybe its your valvetrain(rocker arms..etc.)
what year is your motor?
Old Apr 27, 2003 | 09:51 PM
jonnybravo's Avatar
96.
Old Apr 27, 2003 | 10:04 PM
00 FBP ItR's Avatar
check your valve train...
my friend has a 97 motor and he thought it was detenation as well, but it came out to be the valvetrain..
Old Apr 27, 2003 | 10:38 PM
jonnybravo's Avatar
What in his valvetrain was messed up?
Old Apr 27, 2003 | 11:19 PM
92TypeR's Avatar
FSAE
Does it only occur in low rpms?
Old Apr 28, 2003 | 02:26 AM
Ex-ITR5874's Avatar
Default Re: What can cause low RPM detonation? (92TypeR)
I would say retard timing fist and see what happens..
Old Apr 28, 2003 | 02:31 AM
hanson said's Avatar
Default Re: What can cause low RPM detonation? (ITR1858)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR1858 &raquo;</TD></TR><TR><TD CLASS="quote">I would say retard timing fist and see what happens..</TD></TR></TABLE>
agreed.
Old Apr 28, 2003 | 07:22 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">No, it's advanced to 18 degrees and is fine tuned by Hondata.</TD></TR></TABLE>
Put it back to 16 and use the ignition tables on the Hondata to tune your advance. There's no need to mechanically advance your timing with a standalone, that's what the standalone is for.
Old Apr 28, 2003 | 07:48 AM
PsychO's Avatar
Default Re: What can cause low RPM detonation? (newt2)
If its knocking you could be spinning a rod bearing. Just a guess....
PsychO
Old Apr 28, 2003 | 07:55 AM
sneakychaos's Avatar
Default Re: What can cause low RPM detonation? (PsychO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PsychO &raquo;</TD></TR><TR><TD CLASS="quote">If its knocking you could be spinning a rod bearing. Just a guess....
PsychO</TD></TR></TABLE>
man I feel sorry for someone who thinks a spun rod bearing sounds like detonation.
(NOTE: its a general comment.. just thought it was funny.) weeeeeeeeee.
Old Apr 28, 2003 | 09:11 AM
jonnybravo's Avatar
Default Re: What can cause low RPM detonation? (hanson said)
OK, I'll try that.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hanson said &raquo;</TD></TR><TR><TD CLASS="quote">
agreed.</TD></TR></TABLE>
Old Apr 28, 2003 | 09:19 AM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonnybravo &raquo;</TD></TR><TR><TD CLASS="quote">I'm getting low RPM detonation while under load. Any idea on why? I checked my plugs and they look good.</TD></TR></TABLE>
Pre-ignition is caused by timing that is too advanced and too low octane.
You might also want to check your cam timing if you have adjustable cam gears. Retard the intake cam.
You will probably have to get a minor re-tune unless you can get better gas in there.
Old Apr 28, 2003 | 09:28 AM
jonnybravo's Avatar
Default Re: What can cause low RPM detonation? (Big Phat R)
If I lower the timing through the dist. down to 16, will my Hondata settings all drop by 2 degrees also?
Old Apr 28, 2003 | 09:33 AM
jonnybravo's Avatar
My cams are already at +1,+1 so they aren't very advanced. Do you think I should still retard the intake side?
Old Apr 28, 2003 | 09:38 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonnybravo &raquo;</TD></TR><TR><TD CLASS="quote">If I lower the timing through the dist. down to 16, will my Hondata settings all drop by 2 degrees also?</TD></TR></TABLE>
Yes. the units of measurement on your Hondata ignition maps are degrees of advance. For example is the cell you're currenly in (MAP vs. RPM) has a value of 2 and your ignition timing is set to 16, your actual timing will be 18 degrees.
Old Apr 28, 2003 | 09:46 AM
Big Phat R's Avatar
Just try increasing octane until the pinging goes away.
What gas are you using right now??
