Mini Me swap block info?????
Maybe. There's a chance that when VTEC engages, the valves could hit the pistons - most HF motors only have 2 valve indents on the pistons themselves, instead of 4 (since it's an 8 valve motor, 2 per cylinder).
But even if that doesn't happen, it would be a waste of time/effort/money. The HF bottom end is a POS - it's not going to be able to handle 7k+ RPM rev's, which is something you need to get the most out of a SOHC VTEC motor...
i can tell the block would not be able to high rpm's just looking for a lil power between swaps. I heard the DX head had good gains with the HF block any info??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccrx21 »</TD></TR><TR><TD CLASS="quote">i can tell the block would not be able to high rpm's just looking for a lil power between swaps. I heard the DX head had good gains with the HF block any info??</TD></TR></TABLE>
Like he just said... even without the VTEC head, the HF block only has 2 valve reliefs. You may get contact between the pistons and valves. Just save for your swap.
J.P.
Feb 6, 2006 05:14 PM
ivanson
Mar 8, 2005 08:13 PM
SohcVtecCrix
Oct 15, 2002 07:10 AM
crxfanatic
Apr 29, 2002 10:11 AM
