Annoying squeak
There's an annoying squeak coming from the front driver's side wheel. It's annoying the heck out of me. I'm taking it to get it checked tomorrow, but I was wondering what your opinions are. I've got kyb agx shocks and eibach prokit springs. I also sprayed the bushings with wd-40 so I doubt that would be the culprit. Thanks.
I thought you got the koni's not the kyb's... the squeak is probally from one of your bushings. I'm willing to bet it's the sprng bushing too.
Spraying your bushings w/ WD-40 won't work, you should have used the correct grease...
You're an idiot, I don't know why you didn't ask me first anyhow. And get out of the Integra Forum, you have an Accord!
Idiot, hahahaha....
Idiot, hahahaha....
I just talked to the guy, the squeak doesn't seem to be his suspension, but rather something from the header. It's like a high screech.
Your squeaking is probally coming from another location, and it also kinda depends if it showed up once you put the new springs and struts on or not.
that's weird cause i have KYB AGX's and Eibach Pro KITs, and i am having th same squeeks, from the front and the back of the car, this only happened after i had them both installed.
