Limp Home mode questions
Old Apr 27, 2003 | 04:14 PM
H22ADelSol's Avatar
Default Limp Home mode questions
I currently have a 91 Civic hatch with a D16z6 swap. Recently I installed a Skunk chipped ECU with a redline of 8800. It worked fine for the first week but now it won't run above 100mph and it stops gaining rpm's at 7k. Could this be Limp mode? And if it is, would it be possible for the ECU to not throw a code? The pnly code I'm pulling now is 1. thanks
Old Apr 27, 2003 | 04:45 PM
MrTodd's Avatar
Default Re: Limp Home mode questions (H22ADelSol)
Code 1 is a bad O2 sensor. When an OBD-0 ECU switches to 'Limp' mode, the motor will not willingly rev past 3k.
Chances are you are hitting the cold revlimiter - the P28 (stock Z6 ECU) cold revlimit kicks in at 6800 RPM. It's possible your skunk2 ECU is doing the same. Solution: Buy a 'hotter' thermostat.
Old Apr 27, 2003 | 05:15 PM
H22ADelSol's Avatar
Default Re: Limp Home mode questions (MrTodd)
Not running the stock Z6 ECU though, just a rechipped PM6. Seems odd though, I've never had the problem before 2 days ago, and I've had the ECU for a few weeks.
Old Apr 27, 2003 | 05:37 PM
MrTodd's Avatar
I still think the cold revlimiter is what your feeling. Chances are, your thermostat is slowly beginning to lose it's edge - just replace it with a higher temp model and see what happens!
b20ricepower
Engine Management and Tuning
Jun 4, 2011 03:00 PM
CRXb18Turbo
Oct 20, 2005 05:48 PM
initialR
Jan 10, 2005 10:06 AM
SOHC_MShue
Nov 11, 2004 11:52 AM
kim_2_da_chee
May 30, 2003 06:18 PM
