a little OT: mushy pedal feel??
Old Apr 27, 2003 | 04:14 PM
py1188's Avatar
Default a little OT: mushy pedal feel??
Quick question
What would contribute to a real loose pedal feel? The pedal on my new car goes almost all the way to the floor, and the lines or fluid have never been changed. Do you think swapping the fluid only would help resolve the situation, or is it attributed to something else?
Thanks in advance
Old Apr 27, 2003 | 04:16 PM
.RJ's Avatar
.RJ
Default Re: a little OT: mushy pedal feel?? (py1188)
The fluid will absorb moisture over time, so yes - flush the fluid and see if that helps
Old Apr 27, 2003 | 04:17 PM
cheezthis's Avatar
Which pedal? Check master cylinder for leaks and fluid levels.
Old Apr 27, 2003 | 04:30 PM
py1188's Avatar
Default Re: a little OT: mushy pedal feel?? (cheezthis)
. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheezthis &raquo;</TD></TR><TR><TD CLASS="quote">Which pedal? Check master cylinder for leaks and fluid levels.</TD></TR></TABLE>
Brake pedal. I checked fluid level, and the lines. The lines seem to be fine, and the fluid is full, but looks a little old
Old Apr 27, 2003 | 04:33 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py1188 &raquo;</TD></TR><TR><TD CLASS="quote"> but looks a little old</TD></TR></TABLE>
Flush it
Old Apr 27, 2003 | 04:37 PM
cheezthis's Avatar
Default Re: a little OT: mushy pedal feel?? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Flush it </TD></TR></TABLE>
I need to do the same to mine actually...but my brakes have more problems than just that.
Old Apr 27, 2003 | 04:41 PM
py1188's Avatar
I guess that what I'll try first, then go from there
thanks
maxogsr
Oct 4, 2009 01:51 PM
unrefined7
Jan 22, 2006 09:10 AM
Batoutahell
Apr 2, 2003 07:54 PM
civic_sir94
Mar 3, 2003 11:41 AM
OzzieAccord
Jan 30, 2003 12:39 PM
