H22 swap (cable tranny) question?
Old Apr 27, 2003 | 03:50 PM
Hondasaurs's Avatar
Default H22 swap (cable tranny) question?
I'm currently swapping an H22 into a 92 Civix DX hatch. I am using a 90-93 Accord shift box. The problem is the cables push back when I try to shift through the gears. What do you recommend to stabalize the trany cables?
Old Apr 27, 2003 | 04:11 PM
junglerunna's Avatar
Default Re: H22 swap (cable tranny) question? (ZC_CRX)
I had that problem too, I had to go to Honda and purchase these 2 clips that held them in place. I think there were like $4 ea. if you have the helms you will see exactly those 2 clips that you most likely didnt recieve with your motor. Which was what happened with me.
Old Apr 27, 2003 | 05:03 PM
One 38's Avatar
Default Re: H22 swap (junglerunna02)
yup yup the clips are the key i couldnt find anywhere that sold them while doing my swap so i used like 10 zipties on each cable
Old Apr 27, 2003 | 06:33 PM
Jonathan_ED3's Avatar
Default Re: H22 swap (Monk-)
I've got two clips leftover from my swap if anybody needs them.
Just shoot me an IM and they're yours
BTW, the clips on the shifter assembly and on the tranny are the same...you need 4 total.
Old Apr 28, 2003 | 09:49 AM
Default Re: H22 swap (hot_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EG &raquo;</TD></TR><TR><TD CLASS="quote">I've got two clips leftover from my swap if anybody needs them.
BTW, the clips on the shifter assembly and on the tranny are the same...you need 4 total. </TD></TR></TABLE>
Correct, mine just happened to come with the 2 on the tranny and thats it.
92civlude
May 8, 2009 11:35 AM
Chris Crane
Jul 24, 2008 04:32 PM
djSALIX
16
Oct 21, 2005 10:59 AM
9WON4
Apr 5, 2005 08:58 AM
Boostless97Lude
Dec 24, 2002 04:59 AM
