how to wire them little l.e.d.s?
Old Apr 27, 2003 | 02:53 PM
silveraccord01's Avatar
Default how to wire them little l.e.d.s?
hey, i was messing with my car and wires yesterday didn't know what i was doing but still didn't work only works if the car is off. i just split a lot of wires to try and get a positive and negative to power just TWO! leds? so right now i'm just using 2 6 volts batteries to power my leds do i need a relay thing and connect wires to my battery? and use the power source from there? thanks
Old Apr 27, 2003 | 04:42 PM
Archidictus's Avatar
Unceasing Measure
Default Re: how to wire them little l.e.d.s? (silveraccord01)
I'd start by putting them in your ***.
Old Apr 27, 2003 | 05:20 PM
kay_animation's Avatar
What are you trying to do with the leds? Why are you hooking them up?
Old Apr 27, 2003 | 05:25 PM
Unceasing Measure
Default Re: how to wire them little l.e.d.s? (kay_animation)
On a serious note, though, you can wire them to any positive, switched source and any ground and they should work fine when the switch for your "hot" wire is activated. If you can't make it work using that formula, you should definately practice moving your car around the block only using your starter motor .
Old Apr 27, 2003 | 06:17 PM
COMplex.'s Avatar
Default Re: how to wire them little l.e.d.s? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">you should definately practice moving your car around the block only using your starter motor .</TD></TR></TABLE>
haha, i'm glad you mentioned that.
i blew a headgasket on my friends subaru, and it kinda just died in the middle of the road, so i left it in gear and kept turning it over (it wouldnt start) and the starter motor got it to move far enough off the road. lol
Old Apr 27, 2003 | 06:21 PM
Unceasing Measure
Default Re: how to wire them little l.e.d.s? (j.fuggi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j.fuggi &raquo;</TD></TR><TR><TD CLASS="quote">
i blew a headgasket on my friends subaru, and it kinda just died in the middle of the road, so i left it in gear and kept turning it over (it wouldnt start) and the starter motor got it to move far enough off the road. lol</TD></TR></TABLE>
Great way to ruin a starter, but fantastic way to creep out of traffic if your engine's shot
Old Apr 27, 2003 | 08:04 PM
pr0jektdc2's Avatar
on a serious note i had a blown tach with a LED shif tlight and i hooked it up to my original LED and found out it will not work unless it is hooked up in a series form...u cannot just tap into the wires and expect it to work...took me awhile till i looked online and found a artical on it...
Old Apr 27, 2003 | 09:11 PM
prendi's Avatar
Default Re: how to wire them little l.e.d.s? (pr0jektdc2)
put a buncha stickers on your car and they'll magically light up
Old Apr 27, 2003 | 09:21 PM
iam7head's Avatar
Default Re: how to wire them little l.e.d.s? (prendi)
what source of power you getting from? 12v?
give me the number and i'll let you know what ohm of resistor you need.
oh yeah..what LED you using?
Old Apr 27, 2003 | 09:22 PM
iam7head's Avatar
Default Re: how to wire them little l.e.d.s? (iam7head)
use 12 volt of your car's power source instead
Old Apr 27, 2003 | 10:35 PM
aites my fault, just thought of using them as a substitute for the neon tubes, sorry for wasting a post my bad
wifesaynogo
May 24, 2006 04:36 PM
tommymoose
Audio / Security / Video
May 1, 2006 06:40 PM
bassisliffe
14
Jul 17, 2004 05:28 PM
OldSchoolHatch
Jul 12, 2003 09:55 PM
blitz-integra
May 20, 2003 09:50 AM
