has anyone tryed cold welds??
Old Apr 27, 2003 | 06:43 AM
EG6[B16A1]'s Avatar
Default has anyone tryed cold welds??
hey guys, last nite I broke the bleeder off my motor mount, I was wondering if any has tryed cold weld to hold down metal to metal, or should I just get it welded???
here what came off, http://www.imagestation.com/pi...d.jpg
please gimme your advise on this..., thx FISH
Old Apr 27, 2003 | 06:58 AM
Francois's Avatar
Looks like the bleeder from the Thermostat housing...
As a machinist,I do some cold welding...Unless there is some rod in Aluminum,I don't think that would be possible.
Even if it was made in steel(The casing),that would not be enough as far as strenght is concern.
Get another one...it's cheap.
You could weld it but not with cold welding.
Maybe you could use Epoxy,but I'm not shure if it will hold enough if you need to open the bleeder...
Old Apr 27, 2003 | 07:07 AM
EG6[B16A1]'s Avatar
Default Re: (Francois)
can I get this Epoxy stuff at my near Canadian Tired store??? would you noe where its available? thx for your time
Old Apr 27, 2003 | 07:12 AM
Francois's Avatar
YUp,Canadian tire sells Epoxy.
Maybe you could check in the parts department if they have in stock,the water outlet housing...
'Cause to me,it looks like that.
robbyptown
Honda CR-V & Element
Mar 26, 2013 05:54 AM
triple
Jun 8, 2010 08:09 PM
alscrx
10
Jan 3, 2008 06:57 PM
Tyler Con
14
Sep 13, 2007 07:42 PM
95ACRED
Jan 12, 2002 07:02 AM
