To all ZC owners!!!
Old Apr 27, 2003 | 12:05 AM
SiRWannabe's Avatar
Default To all ZC owners!!!
which distributor are you using?? if you have one from an 88-89 integra, did you have to rewire something or was it a plug and play?
Old Apr 27, 2003 | 12:43 AM
carsaregood's Avatar
Default Re: To all ZC owners!!! (SiRWannabe)
plug and play
Old Apr 29, 2003 | 03:55 PM
SiRWannabe's Avatar
Default Re: To all ZC owners!!! (carsaregood)
even if you have a DX?? is the Si distributor harness the same as a dx?
Old Apr 29, 2003 | 03:57 PM
turboZChatch's Avatar
Got this link off a fellow h-t memeber and it sums it all up http://www.geocities.com/civiczc/zcwire.html
Old Apr 29, 2003 | 05:10 PM
FourthGenHatch's Avatar
Default Re: To all ZC owners!!! (turboZChatch)
I have a DX and I had to swap out my distributor plugs (just de-pin one and stick it in the other) and it worked 100%.
Old Apr 29, 2003 | 05:39 PM
markw's Avatar
Default Re: To all ZC owners!!! (FourthGenHatch)
Ok, the easiest thing to do with the DX is to BUILD a 2nd harness. This harness will have 6 connectors. Use parts off an Si harness or whatever you can salvage at the junkyard. You need the connector for the cam angle sensor, 4 injectors, and the resistor box, plus a resistor box. You should also have some heat shrink, and a place to build this. Use soldered joints, none of those crimp on connectors. This harness is going to make a stop at the cam angle sensor, then 4 injectors, then loop over to the reistor box, following the stock path. You will also need some pins for the ECU, we've done quite a few mpfi swaps with this setup. For the ZC, you keep the DX distributor plugs and just plug them in. The second harness will take care of the angle sensor. (blue wires) Here's a finished swap: http://www.wolfenet.org/gallery/zc/IMG_0706
Old Apr 29, 2003 | 06:43 PM
redzcstandardhatch's Avatar
something different
Default Re: To all ZC owners!!! (markw)
my standard plugs, which i thought were the same and dx, plugged right into my 89 integra....no swapping anything. i have a 90, if that makes any difference
mikeyindigo
Apr 6, 2016 09:16 PM
knightsef-eg
20
Jan 2, 2009 01:51 PM
StupidSlowRSX
Aug 30, 2004 02:58 PM
ITR981002
Jan 27, 2004 07:48 AM
