smc500 im getting atmospheric pressure code and trottle angle,any ideas?
Old Apr 26, 2003 | 07:05 PM
civicguy's Avatar
Default smc500 im getting atmospheric pressure code and trottle angle,any ideas?
im tired of this thing throwing codes,i used a gun to solder the wires,idle is nice,before i start up the car atmospheric pressure code comes in and as soon i press the gas trottle angle code comes in too,im tired i asked on the fi forum but no answer,
thanks in advance for any help
Old Apr 26, 2003 | 08:54 PM
altoid's Avatar
Default Re: smc500 im getting atmospheric pressure code and trottle angle,any ideas? (civicguy)
what numbers are those?
Old Apr 27, 2003 | 06:49 AM
civicguy's Avatar
Default Re: smc500 im getting atmospheric pressure code and trottle angle,any ideas? (altoid)
code 7 and code 13
Old Apr 28, 2003 | 02:19 PM
Deltax75's Avatar
I'm in the same boat. I've got an SMC500 and i throw a code 13 too. But mine comes on after a bit of driving. Are we not trimming enough fuel? Any help would be appreciated. -Mike
Old Apr 28, 2003 | 03:18 PM
zCivic's Avatar
Default Re: smc500 im getting atmospheric pressure code and trottle angle,any ideas? (Deltax75)
My sig has them helm shop manuals for codes....search and you will find
Old Apr 28, 2003 | 05:16 PM
Deltax75's Avatar
Bro, I know you were just tryin to help, but if you read the post through you would see that we know what the codes mean. Why are our SMC's causing them is the question. Especially since it says right in the SMC FAQ that it has a special feature to supress Barometric code 13's.
Old Apr 28, 2003 | 05:44 PM
zCivic's Avatar
Default Re: (Deltax75)
But still something is out of whack some where. It only runs off MAP?? That sensor has nothing to do with BARO or TPS?? I only used a VAFC and I know you tap into the TPS only to get the throttle postitions for part and WOT fuel maps then cut and paste the MAP to adj voltage to the injectors. Even with that wired up the TPS will read the same and the BARO will still read within specs. Its a stock ECU why would adding that throw CEL....
hondachris1994
12
Aug 15, 2008 03:13 PM
mygfs92lx
Jul 21, 2006 08:00 PM
93b18civic
Mar 21, 2004 06:48 PM
whagkangmakulet
Nov 21, 2002 09:46 AM
smkngsr
Oct 22, 2001 08:05 PM
