Flat tire rim stuck on car need help asap
i got a flat tire last night and this morning i took all the lugs off and the rim is stuck on the hub of the car ne one know how i can get this off NEED HELP ASAP
take either a rubber mallet or your foot and get pissed at it, just kick the **** out of it, or beat the **** out of it. It will come loose
Set the car back on the wheel, but with no lug nuts. That usually breaks it loose. If it doesn't, put it on the wheel with no lug nuts and give it a good kick.
raise the car and get a mallet or something and hit it from the back side of the tire... we had a big heavy steel tube with handles on it that we used on wheels stuck to the hub at a shop i used to work at, but that should break it loose... if not, spray the crap out of it with some lube, wd40 or something, and let it soak... i guess be careful if you've got expensive wheels doing that though...
