Help Need You Guys Suggestion
i just got a quot from a well known performance shop in toronto called Leitner performance tell me what you guys think of this price its a type r motor goign into a hatch for turboing thanks ............any suggestion would be appreciate ..........
LABOUR
Rebuild engine $1300
Port & polish head $1000
T-Top Block $1500
Knife edge crank 200
Balanced bottom end 250
Lighten and resurface flywheel 150
Match port manifol 120
Bore throttle body no charge
Polish crank no charge
Resurface Head no chrage
PARTS
Wiseco Piston 9:1 800
Crower Rods 1500
Crower turbo cams 1200
Crower spring/valve/ti-retainer kit 1400
JG Edelbrock manifold 550
Hondata gasket 120
O.E.M gasket kit 330
Main bearings 111.00
Honda Oil Pump 185.00
Honda water pump 150
honda timing belt 115
adjustable cam gears 250
TOTAL: 11095.00 CDN dollars
LABOUR
T-Top Block $1500
PARTS
Crower Rods 1500
Hondata gasket 120
If you're going to turbo it dont waste your time with a ITR motor.
I'm sure theres better ways to spend $11000. Like... shocks, tires and track schools.
**** btw its 11000 grand CDN
and i have an ITR already i wanna low 12 sec car
the 11 g does not include the turbo kti etc i have around 15-20 to spend on my engine........
that sounds like a bit much still...but then again, you're paying for a shop to do it.
you'd be better off selling the ITR motor and using the extra cash from that to drop in a B18C or the like. Resleeve and bore to 2.0l, etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sparco_TypeR »</TD></TR><TR><TD CLASS="quote">**** btw its 11000 grand CDN
If you wnat a low 12 second car (or anything thats going to be really quick in a straight line) you're starting with the wrong platform and engine. Sorry, but this just wasnt what the ITR was built for.
So you spend $15K (canadian) on your engine - and then what? You make your 12 second passes and...... ???? There's just no reward in it for me. There's no way that a ITR making low 12 second passes is going to be 100K daily driver reliable.
1st Gen Eclipse GSX + $2500 in Mods = Mid 12 second passes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sparco_TypeR »</TD></TR><TR><TD CLASS="quote">what the
for</TD></TR></TABLE>
"If you wnat a low 12 second car (or anything thats going to be really quick in a straight line) you're starting with the wrong platform and engine. Sorry, but this just wasnt what the ITR was built for."
^^^Thats why.
Not to say it cant be done because it certainly can be done, however you are using the wrong car IMHO. You can probably spend 11,000 CDN, make it a crazy all motor setup, and still break into 12s. And no Im not just another anti-drag racing ITR owner, I just dont think you are going about it the right way.
for</TD></TR></TABLE>"If you wnat a low 12 second car (or anything thats going to be really quick in a straight line) you're starting with the wrong platform and engine. Sorry, but this just wasnt what the ITR was built for."
^^^Thats why.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sparco_TypeR »</TD></TR><TR><TD CLASS="quote">i forgot to mention its goign into a 96 plus hatch</TD></TR></TABLE>
But before you said....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sparco_TypeR »</TD></TR><TR><TD CLASS="quote">and i have an ITR already i wanna low 12 sec car</TD></TR></TABLE>
So which is it?
You're still starting with the wrong platform for a 'go fast in a straight line' setup. Now if you're dead set on it, thats fine too if you think it is worth your time and your money.
There's just better ways to go about this however. Keep whatever honda you have as a daily driver, and pick up a car better suited for this purpose with your budget. A 1st gen eclipse GSX in excellent shape can be had for about $4000, add $2500 in mods and you have a mid 12 second car for half the price of what you planned on dumping into a ITR motor.
Besides, once you collect a few 12 second timeslips then what do you do? Say "wow that was cool" and sit back and frame the slips and thats it? Kind of boring to keep going back to the strip to run the same times over and over.
Cheap. Fast. Reliable.
Pick two. You cant have all 3.
So which is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
So which is it?
Seems to me he has an NA ITR, and he also has a 96 hatch he wants to go turbo with.
Using an ITR engine for a turbo build up in a civic is a waste of money, unless you have one sitting around.
So which is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface »</TD></TR><TR><TD CLASS="quote">Using an ITR engine for a turbo build up in a civic is a waste of money, unless you have one sitting around. </TD></TR></TABLE>
Its still a waste given the amoount of money B18C5 motors fetch
i acutally have a b18c5 sitting aroudn so thats why i want to do it with the r i konw i could buy a b18b or b18c but id rather just do it with this.........or i was thinkin about goign all motor too............but i love the sound of a turbo haahh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sparco_TypeR »</TD></TR><TR><TD CLASS="quote">i acutally have a b18c5 sitting aroudn so thats why i want to do it with the r i konw i could buy a b18b or b18c but id rather just do it with this.........or i was thinkin about goign all motor too............but i love the sound of a turbo haahh</TD></TR></TABLE>
Maybe you should re-evaluate your long term goals/priorities and dont do anything until you figure out what it is you really want to do.
I would sell the ITR, and your motor and buy an STi. Turbo, Fast and Reliable.
yea but i dont have that kind of moeny .......im not even out of highschool yet.......
i just want a sleeper........that i can sometime enter in shows.........how about supercharging would it be more reliable?
In this thread you have said you have:
- ITR
- B18C5 Laying around
- 96 Hatch
- $15-$20K to spend on the motor (which is $10-$13K US)
But you also say
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sparco_TypeR »</TD></TR><TR><TD CLASS="quote">yea but i dont have that kind of moeny</TD></TR></TABLE>
If you are not out of highschool yet finish that first. Your education is the most imp ortant thing. Also, plan to budget as much on your suspension, brakes and tires as you spend on your motor. Having a 12 second car on stock suspension and brakes would suck.
- ITR
- 96 Hatch
But you also say
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sparco_TypeR »</TD></TR><TR><TD CLASS="quote">yea but i dont have that kind of moeny .......im not even out of highschool yet.......</TD></TR></TABLE>
Wow, you're really good at extorting your parents, aren't you?
If you are going to be paying someone to do the work, I assume you will pay someone to do the maintenance as well? In which case, this will be an expensive adventure
i can do the maintence me and my friends can but i dont know how to build a motor that for sure i said i dont have money for an sti which would be like 50 thousdand plus up here .............i was planning on doing 5 lug conversion plus tein coilover etc etc.......**** liek that.........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sparco_TypeR »</TD></TR><TR><TD CLASS="quote">i can do the maintence me and my friends can but i dont know how to build a motor that for sure i said i dont have money for an sti which would be like 50 thousdand plus up here .............i was planning on doing 5 lug conversion plus tein coilover etc etc.......**** liek that.........</TD></TR></TABLE>
5 lug conversion? So do you have an ITR or not? What do you have? Or is this all just a big pipe dream?
If you have 20K to dump into whatever it is you're driving then you would certainly have enough money for a downpayment (at least) on a faster car thats ultimately going to be more reliable and less hassle.
Or.... if you have 20K just buy a damn ITR? B18C5 and 5-lug pre-installed.
Ugh.
Ugh.
Drinker
