Compression....whats it done for you lately?
Old Apr 26, 2003 | 04:15 AM
Superhatch's Avatar
Default Compression....whats it done for you lately?
So Im thinking about putting a milled, p&p a6 head on my sohc ZC block. With a thin gasket Im shooting for about 12:1 compression. My question is this...
Is raising compression that high worth it?
By doing so you take added risks, and the engine becomes (basically) a timebomb. Are the gains worth it? And what kind of gains would you be looking at on a SOHC? Considering that its milled and p&p with a nice cam, should I use a thicker gasket and run on the safer side (around 10+ or so)?
Thanks in advance.
-Jake
Edit: also when a head is milled does it only change the combustion chamber volume?
Modified by Superhatch at 7:34 AM 4/26/2003
Old Apr 27, 2003 | 02:49 PM
Superhatch's Avatar
Default Re: Compression....whats it done for you lately? (Superhatch)
Lie to me if you want...just reply
-Jake
Old Apr 27, 2003 | 03:29 PM
SIRX's Avatar
as long as you are running good enough gas and your tuning it spot on you will not have a problem running high Compression. and yes it will make a big difference
Old Apr 27, 2003 | 03:50 PM
MrTodd's Avatar
Default Re: Compression....whats it done for you lately? (SIRX)
Just make sure you have enough fuel to compensate for the increase compression and extra air! ECU tuning is a vital element for a strong motor.
Acura-Power
Acura TL, RL & ZDX
May 23, 2024 05:10 PM
bluzohh6
24
Jun 4, 2012 12:49 PM
d.n.d.
Jul 17, 2005 08:39 AM
fastaccord94lx
May 19, 2003 05:51 PM
nd8ch
Feb 26, 2003 08:10 PM
