sir-t engine vs h22 black valve cover engine
Old Apr 26, 2003 | 03:16 AM
Eclipse's Avatar
Default sir-t engine vs h22 black valve cover engine
i would like to know which one would be better to put in a 96 accord .should i put in a sir-t engine or h22a(black top).Which One ??and why?? ANd which cams would be best to put in there??
HElp me please i cant decide
Old Apr 26, 2003 | 05:10 AM
carolinaACCORD's Avatar
Default Re: sir-t engine vs h22 black valve cover engine (Eclipse)
IMO, it's a matter of personal preference.
they both have about the same hp, but the H22a has a little more torque.
the sir-t has higher compression, but they usually cost quite a bit more than the h22a.
it's up to YOU.
Old Apr 26, 2003 | 08:18 AM
haccord2.2's Avatar
Yes both motors are a direct swap well at least for the 5th gen. But yea you will pay a lot more for the SIR-t F20B motor and it has less tq than the JDM H22A. As for what Cams to put in the H22A you could go with the JDM OEM Honda Type S cams, or go with the Skunk2 cams which are very good, and then also upgrade the Valvetrain at the same time.
Old Apr 26, 2003 | 08:19 AM
Nick M's Avatar
Default Re: sir-t engine vs h22 black valve cover engine (carolinaACCORD)
displacement displacement displacement displacement
its extremely important, you want the h22a since you are interested in cams which means 'all motor', look at skunk2 cams or Jun
Old Apr 26, 2003 | 12:35 PM
Canonm7's Avatar
Default Re: sir-t engine vs h22 black valve cover engine (Nick M)
What's the saying??
There's no replacement for displacement!
Old Apr 26, 2003 | 06:10 PM
fastaccord94lx's Avatar
Tell that to someone with a b18c5 They'll laugh at you. But yeah, you want the more displacement on big *** Accords, I think the reason is that the more displacement you have the more torque you produce at lower RPMs. That's probably wrong, but other than that I don't see the big difference. :> f20b or h22a, both would be sweet *** engines.
arun92lude
Sep 5, 2010 01:00 PM
BIG T
Mar 16, 2008 07:52 PM
diarrik
Mar 21, 2007 09:28 PM
superturboprelude
Jan 26, 2005 09:09 PM
