new pads with new rotors?
i want to install my new rotors because my car shakes like mad when i brake. should i wait and install new brake pads with the new rotors or can i use the old brake pads with the new rotors? are there any negative drawbacks using the old pads on new rotors? i eventually want new brake pads but i want my car to feel stable when i brake so i want to install them asap. if its ok to use the old brake pads with the new rotors, how would i break in the rotors under these conditions? also, in the future when i get new pads, is it bad to break in new pads on used rotors? TIA
If you dont replace the rotors just make sure you resurface them. That way the new pads will wear/break in evenly. Resurfacing is no more than $10 so its definitely worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiN.DC2R »</TD></TR><TR><TD CLASS="quote">If you dont replace the rotors just make sure you resurface them. That way the new pads will wear/break in evenly. Resurfacing is no more than $10 so its definitely worth it.
exactly a brake job w/ out resurfacing or new rotors... is basically a waste of money... the pads wont last as long will wear away at an angle you will get shitty braking... vibrations at high speeds etc...
if your doing it do it right
</TD></TR></TABLE>exactly a brake job w/ out resurfacing or new rotors... is basically a waste of money... the pads wont last as long will wear away at an angle you will get shitty braking... vibrations at high speeds etc...
well its 18$ for new rotors. so i mean if your gonna do it....
</TD></TR></TABLE>well its 18$ for new rotors. so i mean if your gonna do it....
That's what I would do. Installing a combination of old and new when one is "warped" will often lead to uneven wear and continuing vibration.
If you do end up installing new rotors and pads at the same time, make sure you give plenty of break-in time before getting on them hard. I made the mistake of installing new pads and rotors 2 days before a track event at Mid-Ohio.
</TD></TR></TABLE>That's what I would do. Installing a combination of old and new when one is "warped" will often lead to uneven wear and continuing vibration.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 »</TD></TR><TR><TD CLASS="quote">whats the proper break in procedure for new pads with new rotors?</TD></TR></TABLE>
I think it's 5 soft, 5 medium, 5 hard. might be 10, might be 7. I can't remember. Pick a good number above 5 and stop that many times soft, medium and hard.
xboxhaxorz
Apr 14, 2010 05:34 PM
miksew
Mar 24, 2004 08:45 AM
rody084
Apr 18, 2003 05:32 PM
clm
15
Mar 21, 2003 09:48 AM
